Obviously this is an example of “I don’t know if I can do this” versus “this is what I want to do and I’m going to do it.” I need to remember that on a regular basis. A lot of good work, good example, and good info here.
I hope the MSD is better and bullet proof. It's nice to set it and forget it. I ran a bypass wire to the dimmer switch control in the floor, so I could get home with the RV. The GV that I had in the Challenger.....it was fun splitting gears for a few days, and it quickly became more trouble than it was worth! I did like the way it toned the 3.55 gears down on the interstate though!
Going to cut a piece of wood to the correct profile, then use a jack to press up, and hammer it till it gives!!
I am considering using my shop press. To form steel....
Good question. Planning on reusing cut out piece. Cut smaller and weld in place. It will just fit I think...What are your plans to restore the integrity of the transmission cross member (the part that is a portion of the torsion bar frame that you cut a piece out of)?
No way above. Center console. When the cross member is bolted in. It makes the area strong.If you can, you might consider welding the result to the floor pan, as opposed to the few factory spotwelds involved, to stiffen the piece because you lost a lot of strength there and that part of the frame (the whole piece) is pretty critical. If you do that and have room above, you could make a piece to go above it over the floor pan and weld it in place too.
Not really lost a lot of strength. The cross member is the strength.If you can, you might consider welding the result to the floor pan, as opposed to the few factory spotwelds involved, to stiffen the piece because you lost a lot of strength there and that part of the frame (the whole piece) is pretty critical. If you do that and have room above, you could make a piece to go above it over the floor pan and weld it in place too.
Would you with a RB 500 stroker ?Knowing what I know now....I'll use an A500 or A518 if I ever want OD in another Mopar.
Ok. Resized cut out piece. Gave it a test fit before welding in place
Would be a lot more issues and fabrication.....In Early....A
Not in EARLY A body car. Much different.I'm surprised that it required so much cutting. Almost everyone else has said it just takes a big hammer on the floor to make them fit.
I didn't even have to cut my floor to install a 2004R, but it is much smaller that the GV unit especially in length. I did cut the cross-member and welded a 1/4 inch plate about 3 inches wide and 2 feet long that I heated and shaped on top of the floor above the cross-member. It was hard to bend when red hot, so its pretty ridged cold and you can't see it under the carpet. I welded the entire cross-member solid to the floor pan.
This is how much it needed. It is pushed up as far as it would goNo doubt. My point was the use of 1/4 onch plate that follows the shape of the original floor to bridge the cut out section is relatively easy to make and very effective. The torsion bar cross member does have a significant amount of stress going into it from engine torque and deflection from the torsion bars. More rigid is definitely better there.
Welded in the original piece, just flattened some...No doubt. My point was the use of 1/4 inch plate that follows the shape of the original floor to bridge the cut out section is relatively easy to make and very effective. The torsion bar cross member does have a significant amount of stress going into it from engine torque and deflection from the torsion bars. More rigid is definitely better there.
Yes had to cut out the floor as well....I see. Did the case of the unit protrude that much above the original floor shape once you made room?
Just mocked up but you can see the needed distanceI see. Did the case of the unit protrude that much above the original floor shape once you made room?
