when using the controller i assume? after the triple check of the wiring and install procedure (it has oil, right? ), you can bypass the supplied wiring. it's pretty simple to run the basic wires needed to connect the solenoid through a couple of switches and lights to arm and engage it. with mine, the controller was bad. jumpered it out and called them. they sent me a new one right away.The GV unit.....
