chargers777
- Joined
- Apr 21, 2007
- Messages
- 96
- Reaction score
- 0
Do they fit with power steering? Do they fit on both sides? Any clearance issues?
1973 duster v8 k frame
Ok. They should fit better than the HPs then.I already have the logs
Pretty sure they fit, Tommy. You'll find you will have more and better answers if you create your own thread in the exhaust section, as not as many members will see your question here.RRR ,
I have a 73 Swinger with a Slant ,and an automatic .
Next year I’m anticipating going to a low deck B with a 727 .
The only option this car has is power steering .
I was going to use headers ,,, but I really prefer a nice set of manifolds .
I already have the conversion mounts purchased from Schumacher .
Would manifolds fit alright with my power steering and clear everything ?
Tommy
The HP is needed on the driver side.Ok. They should fit better than the HPs then.
He'll find out. LOLThe HP is needed on the driver side.
If I remember correct I read somewhere a c-body manifold might work. I don't think it was a log.He'll find out. LOL
Correct. I think either one needs milling so the outlet is positioned closer to the block though.If I remember correct I read somewhere a c-body manifold might work. I don't think it was a log.
