purplehazenils
Progress is looking good.
The springclamps you made will make for an uncomfortable ride if you tighten them too much. The stock 'clamps' were designed to only get the leafs together and on top of each other.
I made my own from a few simple strips of iron which I cut to length and wrapped/folded around the leafspring and secured with a weld.
Thank you! Ok so they dont have to be particularly strong its just to hold things in place? I might actually do what you did, what thickness were the strips 2mm or 0.078in should do the job?
