I just read through this whole thread. You did some great work under the hood there. All around great car! I am interested in that lift. Can you share some details about it? Make, Model, do you like it?
Cley
Cley
Any updates? I am curious if you got all 4 wheels on.
Cley
Have you tried, or you should try-when you get back to working on this great looking car- Going back to a mechanical fan, with a shroud, and also with a clutch. Make sure all gaps are sealed around the radiator so all air getting into the engine compartment needs to go through the radiator. Plug any unused holes in the radiator support.
You've replaced a few freeze plugs. Have you given the engine a good flushing out? Mine was loaded with scale and casting sand.
If you still have issues, it is a pro-touring car, put some hood vents on either side, about in line with the pulleys. Air moving up and over the car will draw more air through the radiator and out of the engine compartment.
Have you tried driving it with the hood removed or at least raised a couple of inches at the rear?
Oh, and the obvious one (that I missed once) have you checked the 'actual' engine temperature with an infra red probe or suchlike to confirm the gauge isn't just reading high?
Neil.
Oh man that's painful to look at. Really fortunate that no one was seriously injured. Good luck with the resurrection, and keep us posted on the progress.So after many years it’s finally time to resurrect this project and give an update on what has happened.
In 2018 after putting the car back together it chronically overheated, I tried everything and eventually gave up and let it sit.
In 2020 a friend of a family members friend was given the car to try and solve the problem. The guy was apparently a mechanical genius and “could fix anything”. He removed the engine, pressurized the block, found a blockage in a coolant channel and a crack which was welded, and so the overheating issue was seemingly solved.
I collected the car and drove it home but it came back with the following issues:
-sticky throttle (details to follow)
-severely drained transmission oil, nothing on dip stick
-brake booster moved out with spacers so much that brake power was reduced
-cooling fan moved back from radiator reducing its effectiveness
-engine leaking considerably more oil than before
Apart from the sticky throttle I noticed the other issues on the way home but I figured the main problem was solved and the rest I could fix myself.
The following day was when disaster struck, I had filled the transmission and was test driving.
In an elongated roundabout I gave the car a full throttle blip to see how the throttle response was and the throttle stuck at full. I slammed on the brakes (didn’t help much) and immediately had to swerve to miss a car further ahead, to do this I took a tour over two very high curbs before finally coming to a stop.
It all happened in a couple of seconds so there was no time to reach down and turn the ignition off and just like that every single thing and more done in this build thread was destroyed completely. At the time the car was insured in my dads name with third party insurance, this means there was no money paid out to repair the car. The silver lining was that thankfully nobody was hurt.
I went forth and back about selling the car for a long time but finally decided that if I let it go, I would probably regret it a lot, it is my first car after all.
So, the time as come to fix it, I have been out of collage for four years now meaning I have a more flexible budget hence the change of title from:
1969 Dart budget Pro touring-Daily driver
to
1969 Dart Pro touring daily driver **Crashed**
As for the result of the crash I’ll let the pictures speak for themselves, more to follow.
I. Have a 70 Dart with a factory front sway bar and upgrades very close to yours. I am considering a rear sway bar, I'm not sure what you mean that the Addco rear bar on your car is too big ??Ive got some time off collage and have decided to do some more extensive work on my first and only car so far, a 1969 dart gt. I bought the car about 5 years ago with money from summer jobs, I was really lucky because right after I got it the value of a bodies shot up and are now way too expensive for a young person to buy working part time in Sweden.
I thought it would be fun to put up a build thread to share and have everything in one place.
The plan is to make the car handle, grip and perform as well as possible without spending too much money. I also want it to be a good daily driver so I will hopefully be remedying all small annoying problems.
Motor: Chrysler Smallblock 360ci - 5.9L
Heads: 915J machined to 56.8 CC Std 1.88 / 1.60 valves, compression 9,8:1
Cam: CompCams Xtreme Energy XE262
Carb: Carter ThermoQuad
Intake: Edelbrock aluminiumintake
Ignition: Mallory
Transmission: Torqueflite 727
Exhaust: Doug`s long tube headers, 2.5"system
Rear end: Open diff 8 1/4 -3,90:1
Shocks: Hotchkis Fox tuned
Rear sway bar: Addco 22mm (yes this is too big when running a stock front bar, like I am)
Thank you. Yes all things considered a sticky throttle at the wrong time could do a lot of harm.Oh man that's painful to look at. Really fortunate that no one was seriously injured. Good luck with the resurrection, and keep us posted on the progress.
The wheel going back has done most of the damage to the car itself. Thanks.That sucks. Glad no one was hurt. Seeing how far back the front wheels are now says just how hard you hit those curbs. Hopefully you can find all the parts you need and a frame rack to get the car straightened back out.
The thick rear bar was too stiff for the thin factory bar on the front. The car rolled more in the front than in rear. Car felt weird and the overall cornering grip was probably reduced.I. Have a 70 Dart with a factory front sway bar and upgrades very close to yours. I am considering a rear sway bar, I'm not sure what you mean that the Addco rear bar on your car is too big ??
Agreed and thanks. Unfortunately nothing could be done about the mechanic, frustratingly the of friend of family member situation made it even more tricky.Sorry to read. Why is it that some car guys feel the need to "brag/boast/lie"? Clearly the guy that worked on your car should be held liable and smacked like a *****.
Good luck.
Thank you! I appreciate it.Man that makes it worse. Sorry to read, that's a tough situation. He should feel shame for that, forever.
All the best working thru it. If I had dart stuff I would help you out, unfortunately I've mostly cuda stuff.
Yes this has now been done, the 67 is probably quite a lot more flimsy than the later ones.Can you chop the old idler arm bracket off your old K frame and get it aligned and welded to the new k frame? I’m pretty sure you don’t want to go to the 67 idler arm as you lose handling stability.
Thanks you! It will be a slow repair but eventually it will be back on the road.I'm awful sorry about your pretty Dart. But the good news is it will live again I see! I wish you well with it!
