Can't beat the price, and the work looks really top notch! Looking forward to seeing the reassembly and first test drive.
![:thumbsup: :thumbsup: :thumbsup:](/mopar/styles/default/xenforo/smilies/ATT00014.gif)
Exactly, haha it will be hard to find something as cool.now you need to splash out on a new hose reel, lol.
I put a Borgeson steering box bought from Bergman.. i had to add a PS fluid cooler cause I would lose assist when headers heat soaked steering box. Also had to pull column out and re-orient steering wheel cause splines from steering shaft to box aren't keyed. Now that its all sorted out it is super nice. It does deliver on that modern car steering feel. And my PS is completely silent zero noise at all.
I had manual steering before. Also forgot to mention first PS Pump stopped working and Bergman gave me another new one. Not sure if heat killed the first pump or not? So had a few challenges struggles but well worth the effort .I remember reading about your issues but didn't know that this was the cause. Any idea why this was not an problem with the original box, or did you go from manual to PS? I luckily got a cooler from Bergman but will certainly look out for similar symptoms.
That's a good point, Ill keep an eye out for that.With the torsion bars fitting snug against the clip, if there is any flex, could it pop the clips out?
It's been a long time since I've swapped bars and don't remember the amount of spacing there was.
Keep up the great work!
