abdywgn
dismantler
a tip from Hot Rod was to angle the turn downs inward; said to reduce the drone
Or you can angle them out for bigger smokier burnouts.a tip from Hot Rod was to angle the turn downs inward; said to reduce the drone
Ok yeah I vote angle them out sounds like a winner to me....Or you can angle them out for bigger smokier burnouts.
Working on it...............getting closerYou burning rubber yet? Quit slackin and get her done! lol
I ordered a different fan and narrow spacer from Summit, it was delivered yesterday, should do the trickDid you guys get the radiator / fan clearance sorted out? I would be lucky to have 1/4" on my silver Duster.
Love it!here is a little something to look forward to......sorry for the distortion, it is a picture of a poster.
Thank you, he did an awesome job!Rad fan shroud look great!
Thanks, Denny. My FIL had the undersized ones on there and Sean recommended the same thing, using standard. I got standard pulleys from 440 Sourceon the plus side....that 26" aluminum radiator and shroud will cool.
BTW, did you install undersize pulleys or standard ones? For what you are doing with the car, I would recommend sticking with standard-size pulleys, the undersize adds a little HP but slows down the water flow, critical when idling/putting around.
Found it after searching Ansen again...................Ansen?
Yes Sir you are correct..............I searched anson old Mopar bell housing.Ansen?
I bet they are heavy........................Iron bellhousing marked NHRA.You don't want one of those Ansen bells, a buddy of mine had one on his 66 Hemi Coronet and I swear it out weighed the 18 spline 833 that was behind it.
what shroud is that?
