AJ/FormS
68 Formua-S fastback clone 367/A833/GVod/3.55s
- Joined
- Jan 19, 2014
- Messages
- 25,040
- Reaction score
- 12,381
Nope, 2 are from 4 speed cars but not 68s.
OK, understood on the refresh only... and piston change does not make sense for you. If you could afford it, maybe you can consider milling the heads about .030" to bump compression a bit.Well right now the goal is just to make it daily driveable and keep it that way. I guess this is more of an engine refresh than a complete rebuild. I am not wanting to get out of hand with high end performance parts but in my head I figured it would be better to a camshaft replacement now with something that would make the car run better rather than go through the trouble of pulling the engine apart again in the future and replace it if it should come to that.
If I was the op, i'd have already PM'd you...….I got about 4 used ones
All the cams in the world would be mush if your valves don't seal,lol.If I was the op, i'd have already PM'd you...….
One of the cheapest upgrades.... used 340 cam and a factory cast intake.... and one of the hardest to beat in mild hop-ups for a 318. The "freshening up" the OP talks about would be spent "freshening up the heads". All the cams in China are a pile of mush if your valves don't seal
In my opion, camming the thing up, and leaving the 2bbl is a waste of time.
Why not get an Ede Performer and Ede 600, and open up some possibility's ?
Otherwise, slap the stock 318 back in, add electronic ignition, and a free flowing exhaust and be done with it.
Getting harder at the bone yard, I agree. But still can be done on the cheap. a person just has to get busy, and be a little patient.There is probably no way to do this on the cheap, it isn't like there are small block Mopars with 4 barrel setups sitting in the u pull yard, not in my area anyway. .
This combo^^, when properly tuned, is much stronger than most would expect.Stock TQ intake and carb (small primary version)
Dual exhaust off the manifolds
You might not want or need to go any further.This combo^^, when properly tuned, is much stronger than most would expect.
We had a '72 Demon, 318 auto dual exhaust. Put a TQ/cast intake on it. Had 3.23 gears. Very quick, and good on gas.You might not want or need to go any further.
Mill or how about a pair of #302's?If you willing to get an 8-1/4 rear I’d suggest 3.21’s for a driver, 3.55’s for a hotter driver. A nice and mello cam would be 218@050 intake with approximately high .400’s in lift and 6-8 degrees more exhaust duration for the stock heads that should be milled down about .050.
This is about 300+ hp capable of moving the car into the low 14’s high 13’s (weight & gear ratio dependent) and no converter change out.
An excellent driver with reasonable mileage.
Does anyone really know how big the chambers are on 302's compared to other 318 heads? I know different years are different. All my engine books list 302's @ 56-65cc where as standard 318 heads are 60-69cc depending on what year.There all have a small chambered head.
The 302 will port out best according to research and other sources of head porters. But we’re not going that far now are we? He he he he
If a power 318 mill was my target, then a full rebuild with a zero deck piston and ported 360 heads would be the start of the monster.
I’ll dig up my 302’s some day and cc them.Does anyone really know how big the chambers are on 302's compared to other 318 heads? I know different years are different. All my engine books list 302's @ 56-65cc where as standard 318 heads are 60-69cc depending on what year.
Budget = key wordHow about a NOS bottle or a belt driven Paxton Supercharger?
Good idea in theory but how long will the rest of the car last? LOLHow about a NOS bottle or a belt driven Paxton Supercharger?
My 302's are easy to find in the garage. The cc kit not so much. LOLI’ll dig up my 302’s some day and cc them.
