Dang !!! 68 Charger R/T and a 69 Super Bee. I love 66-70 B bodies !!
Thanks, I will have a look at that. I installed it with a gasket and some rtv, but it still weeps a little when parked.suggest that you get a thermostat gasket from Real Gaskets in Tennessee. I've tried other gaskets of theirs and was underwhelmed but that thermostat gasket is great. If you get one FOLLOW THE INSTRUCTIONS. I have one that I have used in a motor for 3 years and I needed to remove the housing twice. I followed the directions and reused the same gasket and it has never leaked.
Thanks. I did the sandpaper and flat surface today, paper gasket and regular rtv was what I had. I think that one of the bolts bottomed out (stupid mistake on my behalf). But that is now fixed. Will let it cure overnight.Flat surface plate and sandpaper to make sure housing is flat. Use a paper type gasket, and permatex "indian head" gasket shellac. It wont leak.
Thanks Mat. My pan is not one of those deep one's, but I have been thinking I should get one of those, so I might just do that. Is it a no, no to put a thin coat of rtv on the pan gasket?They make pan gaskets out of neoprene rubber. Make sure the pan flange is good and flat at the screw holes. It doesnt take much to snug it up. I bought one that's a deep sump pan for a jeep with an A904 from a jeep offroad site complete with built in drain plug. Heavy gage powdercoated steel. Jeeps also use A727s as well. Comes with neoprene gasket, filter, longer screws and filter extender. I think I payed $50 for it. Price has gone up a bit. It's got a built in drain and is really thick gage steel. RT offroad for A904 or A999
Thanks. I will probably get one of those gaskets and use some rtv when installing it. I dont remember what gasket is on there now, but I do remember being thorough when installing the pan. It was nice and straight and everything was clean and nice. The leak is at the front of the pan. I can see it so I'm sure it is the pan.I’d use RTV. And tighten carefully as not to squeeze the gasket out. On other gaskets like the one piece rubber/steel inside, there are “O” rings of brass/steel around the bolt holes. This can just be torqued to specs and forgotten about. Though some RTV in the corners of the pan are needed.
What wheel and tire sizes did you use if you don’t mind me asking.View attachment 1715535970
View attachment 1715535969 View attachment 1715535971
Some more progress from today. My new Indy Mags and tires is finally on so I can show the car forward. It was on my old steel wheels that went flat after a while before. This is the farthest this car has rolled in two years haha.
Thanks. I have a 727. I found these on summit: LubeLocker LLT-A727 LubeLocker Transmission Pan Gaskets | Summit Racingif you look up Torqueflite 904 pan gasket up on the Summit Racing web site they offer a pan gasket with a silicone bead around it. I tried one because of a persistant leak and it sealed right up - had to take the pan off again and reused the gasket and it sealed right up again! You use no sealant with this
Front: U.S. Mags U10115505425 U.S. Mags Indy U101 Polished Wheels | Summit RacingWhat wheel and tire sizes did you use if you don’t mind me asking.
A thin coat is ok. Make sure the flanges around the screw holes are good and flat, and don't over tighten. Permatex ultra black is what we used at the Chrysler dealer years ago when I did that type of work. As a matter of fact the FWD Chryslers of that era used a lot of that Permatex "form a gasket" as we called it LOL.Thanks Mat. My pan is not one of those deep one's, but I have been thinking I should get one of those, so I might just do that. Is it a no, no to put a thin coat of rtv on the pan gasket?
