what size rim and what backspacing is on there....my 15" fit fine , but next to NO backspacing
aren't you gonna run 17's....we put em on Ross's 17x7 w/ 5.125 backspacing...fit nice
the stock (shorter) tie rod end will clear...is this for push-around? that Fatman tie -rod puts the tie rod parrallel with the lower control arm.....needed for correct bump steer geometry....and if 15's are used...must not go too deep on the backspacing...also, you can always remove/unscrew the grease zirk, onced greased
