Stan is bringing the Colt to the Mini Nationals this Saturday in Rockwall, TX. I really want to see the fab work he has done so far. His HyperPak wagon was a really nice show piece, I saw it at the show last year.
I really don't care which way it slants just so it ends up going down the track!!Noooooooooooooo!
All my hard work undone.
Now I have to go back out there and
I’m an Aerospace Tig welder, and recently got to use that Tig machine. I was very impressed and may be picking one up to replace my big Miller machine. EnjoyThis weeks progress.
I needed to put the crank back in, to mount the flywheel, to fit the starter.
So I had to take a lot apart to put it back together.
The starter needs a .250 spacer to move back from the flywheel and a fixture to hold the bottom starter bolt. It looks like the V8 starter location will work and I won't have to cut a hole in the block plate. All this works because I have a starter that doesn't need a nose support.
I needed a TIG welder to do my frame mid plate mounts.
So I sold my MIG welder and bought a Primeweld TIG machine.
That came today, so I need to get up to speed on that.
Also got my valve cover back after getting it cleaned.
It's going to need polishing, but it is clean now.
Also found a Marine aluminum pan. Cast aluminum, 10 quart with baffles.View attachment 1715570762 View attachment 1715570766 View attachment 1715570767 View attachment 1715570768 View attachment 1715570769
383Duster, your inbox is full.
You know anyone at Big D Cycle or the NTNOA group?Hey folks, still here, just took a break to work on my Motorcycle restoration.
I will be back at in a couple of weeks.
There is very very little difference using a crossover pipe in the exhaust of a motorcycle.Does the instruction sheet list Torqueflites or Turbo 350/400 & Powerglides only?
I like the balance tube between the two cylinders. Guessing that gives it more mid-range torque as opposed to
individual pipes per cylinder for top end.
The window in the back ground makes me think it's the living room...I do see the door opener.
Motor Fly's are real light if you get the magnesium wheels . had a set on my 68 Cuda . Would polish them on Friday to go to the track and by Sunday they turned back black . The guy I got them from gave the me the lug nuts for them but he did said hold out your hand , he put a steel mag lug nut in one hand and 5 for the Fly wheels and the steel one was heavier than the 5 for the Fly wheels . They were titanium and were real light . The wheels came off of Roy Hills race car . The Fly wheel could be held up with one finger in the center hole and be spun around with little effort . This was many years ago and I paid $150.00 for 2 wheels and the lug nuts . Just fyi . Great project JohnThanks for your message.
It was pretty crude, this way if something starts to happen, maybe I will see it before it's a BIG problem.
I was looking at Bogart Wheels last night. Maybe I should start a poll, Super Tricks, Brushed Centerlines, or Flys?
Super Tricks, they were on the car.
Centerlines, like a trick, cheaper.
Flys, just a Bad *** Wheel!
Yep they are a lot more expensive now . The ones I got were off his Plymouth Duster that Richard Petty sponsored . I bought them from Billy West , he was good friends with both Richard and Roy .Thanks funnykarman, there is a set of Flys on ebay right now, a little out of my range!
I have a friend who says he has a set of spindle mount Cragars, looking to close the deal soon.
Roy had a Colt, the ex Crider Colt, 340 car.
View attachment 1715631375 View attachment 1715631372 View attachment 1715631374
That's about rite if they're magnesium. And those look the part.Thanks funnykarman, there is a set of Flys on ebay right now, a little out of my range!
