Hyper_pak
Old School Chrysler Fan
Thank you Rusty.
almost every time i work on the car that is in between bouts of looking for the tool i just laid down, that disappeared for an hour, but then showed up exactly where i thought i left it...Little thing I know, but have you ever spent a couple hours and stupid stuff like this?
That head sure is a pretty piece. @RustyRatRodWorking on the head today.
Had a small victory removing the pipe nipple on the bottom of the head.
It had to be removed to clear the engine plate.
Used a pipe wrench, no go.
Used Vice-Grips, no go.
Used a little heat, no go.
Figured I would end up cutting it off and chipping the pipe out of the threads.
Started using my air chisel to split the pipe.
A little while in I saw the pipe move a little bit.
No way I say, kept hammering and it comes loose.
After the pipe victory, it was valve seals, springs and keepers.
Started looking at the rocker arms, they came with flat washers on the rocker arm spacers.
No lock washers, what is up with that.
They look like they will work, but need to check push rods and some other stuff.
View attachment 1715765335 View attachment 1715765336 View attachment 1715765337
One more post tonight.
This is Tom Kocanda, he was the first one to run my Colt.
He sold the Colt in 80 or so to Bob Cope.
Then he bought this Arrow from Alban Gaither.
Alban purchased Sox and Martin's Omni.
These are both paint schemes on his Arrow.
Low 8's but just not fast enough to run the with the big dogs.
But at least he was there, no regrets.
View attachment 1715764786 View attachment 1715764787
Not sure.Yeah that head is badass. Are those T&D rockers?
I got to watch Alban Gauthier's Plymouth Arrow being built by Clyde Hodges who was still building cars for a while at the late Don Carlton garage in North Carolina. That was a lot of big ole Hemi, Lenco, and Dana 60 stuffed into a tiny little car.
I wonder where it is today. ???
1964? altered wheelbase fuel injected turbo slant 6…..
Kinda rough but takes dare to be different to a new level….
One of my slicks went flat sitting on jack stands.
Took the tube out and the valve stem has become un-bonded from the tube.
I took it back to Summit, "Tough Shix", no returns for any reason.
Well Summit sucks on that one.
I contacted Hoosier customer service, waiting on a reply.
Never turned a tire.
dang. well better there than at the top end
