Those will make all that header work worth it Stan
That's just sexy right there.
So you're using the Clifford intake?Linkage is always a challenge.
I had purchased a lever set that controlled 2 carbs at the same time.
This is what that looks like installed.
The right lever is supposed to fit between the 2 spring parts on the left lever.
As you can see spacing is something I didn't expect a problem with.
These carbs are spaced too far apart to use this linkage "solution"
And you can see in this picture the dual lever has a different ratio than the single.
So if it had worked I would have created another issue.
And of course the Clifford throttle shaft is shorter than the Redline system.
This is why one of the carbs is an issue on throttle action.
2 Rod End Bearing Supports VS 3 on the Redline.
Redline
If it was easy........
Are the Italian Webers better somehow? Forgive me as I know nothing about them.Yea, got in too deep before I saw the light!
It's ok, however.....
The intake has shorter runners, problem with headers on cylinders 2 and 5.
Redline is much straighter because of the longer runners.
And the 2 supports vs 3 on the Redline.
Shorter runners should allow higher RPM.
I bought my intake and 2 carbs off ebay a few years ago.
I found another DCOE in another ebay auction.
Same model numbers, just serial number differences.
All of my Webers are made in Italy, not in Spain.
I am just about at 1K now, after rebuilds and all the little stuff.
I was lucky the 4 barrel and carb clear the hood.
Always planned to run the Webers, and no hood scoop.
Redline
Hello Codi
Welcome to FABO and thanks for your 1st message to me!
Glad you are doing your homework.
Sounds like you are going to do a very detailed build.
The upper and lower frame rails are indeed 1.5 inch.
The main frame bars out to the sills are 1.5 also.
The diagonal bars from the 2 frame rails are 5/8.
Mr. Hardy used a lot of different size bars, the passenger side bar on the cage is smaller.
Feel free to ask any questions about the construction as it has not been changed in 40+ years.
Pretty sure there were many Hardy Colts done but I can only be sure of 4.
Roger Denny, became the Rod Shop Colt, Became the Sox White Colt, Mark Panos last.
Pretty sure Roger Denny had the first Hardy Colt.
Ronald Lyles, this was a Sox team Colt, was later driven by Ronnie Sox Red/White and Blue.
Billy Stepp got one.
Cashed at Bristol after the wheelie bars were not put down.
There are pictures of it being taken apart and statements about that being the end of it.
However..... I will just leave it as gone.
And mine, Kocanda and Patrick.
The current restored S&M Colt is the Lyles Colt.
It originally had rectangular front frame rails per the NHRA Rules at the time.
View attachment 1715973615 View attachment 1715973616 View attachment 1715973618 View attachment 1715973619
II was thinking Shirley was into those AMCs.Shirley Shahan ran a early Hornet Pro Stock.
AMC played with the Gremlin first, but performance was not great.
Booth ran the later Hornet with a lot of success.
