Bob at GlenRay has made our Christmas! '73 correct part number radiator and fan shroud he picked up at Carlisle this summer for us
You are getting soft in your old age. Professor Kueneman using a chineseium ignition module??!!??
Never thought I would see the day. Hope you didn't buy it at Merles.
Maybe you figured this out already but the two small connectors in pic 4 are for the horn(s) and the large one is P side headlight (I think).Mocking up of the wiring. A few mystery connectors that I don't know what plugs into them.... Also they don't put the ECU connector in the right spot for '72 Dusters... View attachment 1715263195View attachment 1715263196View attachment 1715263197View attachment 1715263198
****, wiring is easy on these old things. If it doesn't fit, it doesn't go there.
Will do, stay tuned.Yup.... where does the headlight harness ground screw to? Can you take a photo?
Did some of these come with just 1 horn? With the addition of the 26" radiator the horn went under the battery. With the Dart 26" radiator the horn BARELY fit next to the radiator.I was incorrect above, the larger connector is to the turn signal pig tail, not the headlight.
JD is spot on with the ground location for that part of the harness.
Yes they did come with one horn, our virgin base model sure did. We are still running the original harness on ours with one horn. The second lead is just hanging loose.Did some of these come with just 1 horn? With the addition of the 26" radiator the horn went under the battery. With the Dart 26" radiator the horn BARELY fit next to the radiator.
I’d like to have one of those on my demonI was looking for something last night in my stash and ran across one of these..... I think you need one of these on the car Jim.....
