threewood
It's alive!!!
And sounds great, your daughter looks thrilled
Outstanding resto. When does it get the Sharktooth?....sum say worth 'bout 15 HP, not to mention the 100 or so styling points.
Beauty is in the eye of the check holder.Likely never ... I have to grind the back of it to fit the '73 AC dryer in. Would not be able to do that to one of those (not because I like them just because of the value to others). I am clearly still a B-Body guy as I don't see beauty in the Sharktooth or the Rally wheels ;)
First roll out into the sun with a mostly assembled car! The windshield went in after we pushed it back in the garage..
And the little speed demon is getting a bit heavy footed already...
Sounds a little restricted to me. Manifolds I assume? What size exhaust did you put on it?
Pinion seal was leaking just sitting for the week. They are hard to find in stock for a 741 case. Seal replace and the driveshaft is installed. Tim at the driveshaft place said it was an exceptional core shaft. Virtually no balance needed and straight as an arrow. Said is would not vibrate at 200MPH.... Kaelyn had better not try to test that......
The first time this car has moved under its own power since.... the late '90s at least!
Plenty of room!Man....I thought she was gonna whack the garage door for a second there!
