Daaaaannnngggggg...... Now ik why I wanna go with a Slant 6 with a mild turbo in front of a 200r4... Lol!
That's pretty horrendous mileage. I read the entire thread and didn't find what cam and specs you are running. Must have a crapload of overlap.
Thanks for the great post.
If you contact wilcap, they sell the adapter with the required/correct flexplate for your motor.
Unless I'm mistaken, the flexplate they offer is for an LA 360, not the Magnum 5.9. But you're right, them may offer or be able to build a 5.9 version.
Just trying to gather info here before I start calling vendors. At my job, internet time is easy. Time for phone calls is hard.
I'm using the Wilcap kit with my 5.9 magnum / 2004r combo. Very very nice kit. I had to provide a stock flex plate for the balance, but they should have that info on file now.
The kit is 100% bolt-on. The only modifcation needed is to grind/file the tip of the starter to clear the bell housing.
Hate to stray from the original topic, but if I wanted to use a 200R4 behind a stock Magnum 5.9 (externally balanced), how hard would it be to either procure a custom flexplate to mate the two together, OR redrill the Magnum flexplate to match the necessary 200R4 torque convertor? Anyone been down this road, or something similar?
I'm getting a 120K Magnum 5.9 that I don't want to disassemble and internally balance, and trying to figure out the best/easiest way to do this.
Sorry to step on toes -- I can start a new thread if necessary.
The flexplates won't stack like that.
What about installing an MSD 6AL with their sbm crank trigger kit.
http://www.msdignition.com/Products...-_Chrysler_Small_Block_Crank_Trigger_Kit.aspx
The MSD crank trigger won't work with the SMPT computer.
Are you sure they won't stack, even with the crank spacer between them (crank/ to /stock flex plate/ to / spacer/ to Wilcap flexplate)?
How thick would the crank spacer have to be so the flex plates wouldn't touch? That's all it would take to make it work..
Does anybody know how thick the spacer is with the TCI kit?
Interesting informationI am finally in the beginning stages of building a 408 stroker motor to replace my junk yard Magnum with modified factory EFI and 727 in my 68 Barracuda. It looks like a lot of the parts will get here while I'm down at Spring Fling in LA, so the project will begin in mid-April.
After stumbling on the Extreme Automatics web sit (http://www.extremeautomatics.net/), I learned that you can order a modified 200R4 with an adaptor ring that allows you to bolt up a Reid Racings bellhousing. Its the same bellhousing that fits the Powerglides and TH400 GM transmissions. It's just over $600 to mill off the cast bellhousing, fit the adaptor ring and cover the cost of the SFI rated bellhousing, which is smaller than the factory 200R4 cast bellhousing.
This eliminates having to use the Willcap version of the adapter kit, which makes it a lot easier to bolt everything up and then concern yourself with the minor cross member and transmission mount modifications. Once everything arrives, I'll post some pictures of the transmission with the new bellhousing, adaptor ring and torque converter all fitted together.
This development makes the project a lot more friendly for us Mopar engine people. By the way, they also have bellhousings available for Big Blocks and the Gen 3 Hemi's.
Remember, this transmission is a one wire hook-up to get a lock-up torque converter, 2.76 to one 1st gear transmission with a .67 overdrive that can be ordered to handle up to 1000 hp in the stage 3 configuration.
All that's left for an install is some minor trimming and fabrication of a new transmission cross member and modifying a few other connections such as cooler lines, shifter and Throttle valve.
As far as the torque converter goes, you can get a cheaper $200 to $400 custom lock-up torque converters that will bolt up, but I ordered a heavier duty race style 3000 stall, 3 disc lock-up converter from Precision Torque Converters. It has a 3 clutch lock-up, billet engine side plate, anti-ballon plates and fully furnace brazed inards. It's got the Mopar bolt pattern to attach to my Magnum tone ring flexplate, the pilot is Mopar sized and it has the Mopar sized ring gear for the starter. The transmission side is GM. This little gem cost me $800. From what I've learned on the forums, money spent on a good torque converter is money well spent.
I bought the stage 2 200R4 from Lonny at Extreme Automatics. Its rated at 750 hp, but I'm only building my 408 for 500hp/ 500 trq.
I will post pic of the install and any modifications to the rear cross member and the peripheral hook-ups when the job begins.
