Dartfreak75
Restore it, Dont part it!
I can see the alignment being an issue its more resistance and more friction going forward ie more power being used to push the car especially if you have a toe in or out. I know on my dart the tie rods where off and the tires were to toed in and it wore the tires out quick thats alot of extra friction in the front if the car for the engine to push it in a straight line. I'd say a good alignment is worth at least a tenth!Two thoughts are lingering in my mind...…… what if I had a 1/4 inch carb spacer...… many cut the plenum divider lower, I was thinking of a carb spacer..... could a tenth be sitting there? And my front end alignment is way out of wack. I've heard of as much as 3 tenths in just the front end being "aligned" properly.... what if I got a tenth there….
I don't know enough about carb spacers to comment however I did see a dyno video on youtube were a guy had pretty big gains by adding a 1 inch spacer.
