j par
Well-hung Member
Which actually does bring up a good question, at what point are you going to be making enough power to start breaking the tires loose even with those gears?
I'm continuing to tune the car to hook. The "Action Traction Bars" are working hard to make both wheels spin. Remember, there is "some" amount of power and torque there to cut a 1.92 with 2.76's and a stock converter.Which actually does bring up a good question, at what point are you going to be making enough power to start breaking the tires loose even with those gears?
I'm just saying when you ad more power to get to your goals...I'm continuing to tune the car to hook. The "Action Traction Bars" are working hard to make both wheels spin. Remember, there is "some" amount of power and torque there to cut a 1.92 with 2.76's and a stock converter.
I don't know.... I'm still at 32 psi in the back tires. If I cut 1.85 and that's the breaking point for the tires holding, I can pull air out of the rears until it hooks... maybe 25 psi?? again, I won't know till I get there. By the way, 1.85 should get me my goal with ease.But any one of those two combinations and it may add up to some Tire spin?
Yeah, I did the drivers side - all new bushing (Upper/lower control arms), upper/lower ball joints, strut rod bushings.... why it took me this long to get to the passenger side, I don't know.View attachment 1715374975
I've never had to do that...lol
Mine went down the road ok, but the bushings were just dry rotted.I had my buddy line it up a long time ago and he told me the front end was shot. I drag race and did wheelies and the whole nine yards. I finally rebuilt that suspension last year and it's been a dream on the freeway...
I lost one too.... LOL...I lost 2 vote from last week an j par picked up 2.
Who's running that pole CNN?
Wth? Does anyone even read the thread before they vote?I lost 2 vote from last week an j par picked up 2.
Fighter is ready in the blue corner.... LOL.Has this race happened yet? No. So yall both hush up and get busy. Talk's cheap.
Holy Moly! It's back together and that raised the front end up about an inch on that side. I let the torsion bar down some. I'll drive it around the block and check on the alignment "by eye", eye guess.... LOLBusy as a bee..…….
I'm installing new UCA bushings and upper ball joint... (finally getting to the passenger side)
Thanks! I thought you might have a manual...… LOL
I figured you had all specs at the tip of your tongue. lolThanks! I thought you might have a manual...… LOL
start'n to slip a little.....I figured you had all specs at the tip of your tongue. lol
