273 or NOT 273?
Um , factory commando 273s had 235 hp with exhaust manifolds and a 500 cfm carb and they can easily make over 300 hp with some good bolt ons. Just think if you built one from the Pan up.
Gee I'd love to get roped into an argument wit ya but...Ill just cut it short by saying I have 2 340s so there... nyahhh...:lol:
Just remember, the 235/273 had more horsepower/cu. in. than the 340. :poke::rofl: (I know, it's all about how it's rated)
You are talking about teh commando? the interwebs says this: The 273 (4.5 L) was the first LA engine, introduced in 1964 and offered through 1969, rated at 180 BHp.
also I have understood that a 273 was is about the same as a base 318 or id concede 185--230 HP. Now a 340 can be tuned to right about 330-340 HP. Nicks garage spun one recently to
335 horse i think it was. I do enjoy the "little engine" arguments on here but i try not to get roped in too far with it.:) The 340 comment was a "yeah well my dad is bigger than yours" playgroundreference...:)
The 273 4 barrel that was in production between 65 and 67. Rated at 235 horse. Then of course there was the 275 horse D dart engine in 66.
""Tipping the scales at slightly over 2900 pounds, the 275-horsepower Dart fell into NHRA's D/Stock category-thus the car's appropriately fitting handle. Underhood, aftermarket parts included a 284-degree, ½-inch-lift Camcraft camshaft, Racer Brown valve springs, Doug's headers and a 4160 Holley carb adapted to the stock 273/235 iron manifold. A New Process A-833 4-speed gearbox was twisted by Weber clutch components and smoothly shifted by way of Hurst. Underneath, a "big car" 8¾-inch rearend carried a Sure-Grip center section and standard 4.86 gears. About the only items that this fleet factory rod didn't come with were air conditioning and a warranty."" (from an article in Hot Rod Magazine.
Yeah 318 was the same at 235 horse I recall but then became a smogger in the early 70s as well as 340 and 360. were smogified. The later 340 was rated 235 :)Ha! All 3 were rated 235 at some point. :lol:
I sell engine parts all day long and I am never going to tell a guy what he should buy, but I do make suggestions based on what I do know.
Just an FYI: All of my kits that I sell I use King XP bearings in. You can no longer just buy a regular XP bearing for the small journal crankshaft mains. Because they just don't offer them.
You can still get them non coated for a 360 because they still sell the volume. The small journal bearings are now only available in the coated version which cost double.
I also try to convince my customers to build engines that use readily available, off the shelf parts that will still be available down the road (or at least we hope)
For what it's worth one of the best running SBMs I've ever driven is a 380" 360 with ported iron heads, a ported iron 340 intake, and a smaller AVS. It will not hook up on street tires.
If you have good ring seal, a quality valve job, and a reasonable cam they will all give you a smile on your face when you stab it to the floor. One should always build what they want,
but smaller bearing and smaller bore engines are going to cost you more in today's world. Building an engine with at least a 4.00" bore gives you the most piston options available at the
most reasonable cost you can get, and the highest availability. Most of us work everyday and aren't sponsored in our racing efforts. Parts go up 5%-6% every year, engine building is
getting to the point most can't afford it any longer. That's why I advocate a careful selection of parts that provide the most cost effective solution to ones wants.
On with the 273 or Not.
Tom
Ok I'll tell a 273 story. It was the 80s I was maybe 14 or 15 but knew what I thought I knew about cars, anyway there was a guy in the neighborhood with a 66 barracuda, keep in mind this is when the car was maybe 19 or 20 years old. He had the hood up...I walk over a clueless punk that I was and probably said "what's it got in it...?" the guy said "273" I was like "273? what is that...?" and he explained. the guy was probably 20 years older 33 or 35 etc. but that is the first id ever heard of 273. In the 80s the big Mopar was 383, 440, 340...318 etc. Chevys were 327 350 400 396,454... Ford was 5.0 , 351 Cleveland, Windsor, Modified etc. 273 to me was an odd ball never heard of it.
273 I have no problem with any of them but Id build it with realistic goals. I'd redo a 273 to put in a 66 Barracuda and probably stick to stock specs and expectations. Tune it well see what it does in street dress etc. I actually was looking at a 65 Barracuda maybe 6 years ago they guy wanted 5500 but it disappeared. Not sure if they are going that affordable now.
I have three 340's. They are waiting till I get bored with the 273. So far the 273 has been in one of my Barracudas for 50 years and still the 340 just sits on the engine stand...
OK few things , who said my 340 won't have a lot of HP? Gotta love the ignorance of the new stroker mentality. Been going 11's with a mild 340 since before stroker kits were around and I plan on building a lot more Than I have now ( I'll actually ports my heads and intake on this motor ). 2nd , biggest misconception , just because you can rev to 7k , doesn't always mean you are making power to that RPM. yeah , my 340 can rev over 7k , but why would I? I shift it at 6800 because thats where it's best shift point is. 3rd , OK , you have over 400 cu inches , congrats , last time I checked , I build what I want , not what 98% of the small block mopars build because it's "cheaper" or "Makes more power"
nobody mentioned the hp of your 340 except you. if the second comment was aimed at me i've been building engines for myself and freinds for 40+ years so ignorant i'm not :thumbsup: . saying a stroker will rev to 7k was just a comment based on your 'want' for a high revving small block that inferred a stroker then wouldn't/couldn't be high revving. my point was with parts matched to each motor's size the bigger one will make more power and at high revs if that's how you want/build it. i'm glad we don't all build the same thing or it'd be pretty boring. back to the start here, given the choice (if i had both) i'd build the 340 rather than the 273 purely on the basis of bang for the buck. good luck with it whichever you choose to build.
neil.
Correct me if Im wrong but isnt the parts selection for 273s limited? things like gasket kits that don't work or aren't available? OR is it true that a fel pro gasket kit is out there for 273? i think in terms of overall headache on a build .
I already looked into it and decided to build another 340.
Yeah I mean I have nothing against any of the LA engines but I know or think 273 stuff is limited availability wise etc. and who knows going forward alot of it may be I'm sad to say.
You are misinformed. 273 uses everything the same as a 318 or 340 except pistons and rings.
Gaskets really aren't an issue. 273/318 gaskets are interchangeable except for the original steel shim head gaskets which aren't made any more. More Information for FEL-PRO FS8553PT9
The PT head gaskets in the kit will work fine. I used these instead. Thinner and just a bit smaller bore. There are always Cometic gaskets as well. DODGE Mr. Gasket 1121G Mr. Gasket Head Gaskets | Summit Racing
Amen , " Oh my 416 inch " small block " revs to 7500 , meanwhile the powerband is 2800 to 6400 ,
Unless you got great cylinder heads lot of them peak before 6000 rpm and hp quickly declines after the peak (falls off a cliff).
the Teen was 230 horse.
USA specifications273 V8318 V8 (LA)340 V8
Gross horsepower, 1968
(1962 for 318-A)
190 @ 4400230 @ 4400275 @ 5000
Torque, lbs.-ft. , 1968260 @ 2000340 @ 2400340 @ 3200
Compression ratio, 19689.0 to 19.2 to 110.5 to 1
Bore, inches3.633.914.04
Stroke, inches3.3123.3123.312
Carburetor type (1968-73)2-bbl.2-bbl.4-bbl.
FuelRegularRegularPremium
The chart needs a tune up. The 273-2 barrel was rated at 180 not 190. There is no specs for the 273-4 barrel which was rated at 235 horse and 260 lb/ft of torque. Now look at the 318, 5 horse less than the 273-4 but 340 lb/ft instead of 260 for the 273. (and at a lower rpm with the 318)
1967 283 V82 barrel4 barrel
Gross hp (Valiant)180 @ 4,200235 @ 5,200
Torque (Valiant)260 @ 1,600260 @ 4,000
Bore and Stroke3.63 x 3.313.63 x 3.31
Compression Ratio :18.810.5
I wish the police pursuit 318 4bbl would have been rated in Gross... I drove one all original in a Volare, it honestly was one of the fastest stock LA's I've driven.
Mid to late 80's? Roller cam engine with 302 heads?
