Here is another 71 non Swinger deck lid.
I ordered some from eBay, 3/16 hole and 1/8 emblem stud, install the barrel clip first then add a little sealer on the emblem studs push in gently and evenly...Where can I get barrel clips?
YepJust to add to the information, the original Dodge cursive emblem on the trunk in 1970 is identical to the one on the hood EXCEPT THAT IT HAS 2 POSTS none of which are in the same place as the 4 posts on the hood emblem. I'm sure many have ghosted their tired original emblems onto the lid with primer and closed the old holes and drilled new ones to match the 4 post hood emblem - once in place no one would ever know.
trunk and hood emblems
original trunk emblem
4 post hood emblem
SEALER AROUND THE POSTS - YOU DON'T WANT WATER SEEPING INTO THAT PROBLEMATIC BOTTOM TRUNK LID SEAM!!!
I saw that Dicer sent you a pic with measurements for the trunk lid emblems. Do you have the information that you need to locate the quarter panel emblems?
You are right about the straightness of pins issue, but if you try to straighten them up permanently you might just snap them off. The place that is critical is where the pins contact the emblem body. if you have to flex things to get all the pin tips in that's ok if when you GENTLY push it in it get progressively easier. I tried to install a DART sign by using the tips of the new emblem to mark the hole locations, since the pins weren't exactly straight, when I pressed it in it put more and more pressure on the little link between the A and the R and it snapped just before it was in place (((sigh))). I would suggest that if you have old pitted emblems that you snip off the posts 1/8 inch from the emblem, that way you can accurately locate the emblem on the sheetmetal and use the clipped points to mark hole locations in the old paint. If you can get the old originals to fit, my experience is that repops will slide right in.
There is a plastic version of the barrel clip that might be just a tad more forgiving. If you want a couple pitted Swinger and Dart emblems to help your project as test fits, let me know and you can have them for postage.
For sure you want to drill all the holes (and close unneeded holes) before paint. Like I said earlier, I think the plastic ones are more forgiving when you don't have factory holes. Sources for emblems - Layson's Restorations (they have a vendor link here), Year one, Classic industries should have the Swinger and Dart emblems and the cursive Dodge for your hood and even the gold pentastar for the bottom of one front fender. Sometimes the emblems come with the plastic barrel clips. I'd get some new clips, put them on an old emblem and do some test fitting on a scrap piece of sheet metal. The plastic ones should slide, with no resistance into the hole until you get to the swell at the end (see earlier poster's picture).
When you say "hood" you mean trunk lid right? If you are talking about the holes in the inside trunk frame, I think two of those line up with the two posts in the old Cursive Dodge emblem (see first picture in post 35 above) and since they were not seen, they probably didn't bother to delete them between 1970 and 1971 (when they changed to the block letter Dodge emblem (post 10).
Your hood (over the engine) should have 4 holes for the 4 post cursive Dodge emblem with provision for retainer nuts on all four posts via holes in the hood frame. One of those holes is slotted. The emblem that you buy will be flat and the first time it is installed you tighten the nuts and bend the emblem to conform to the curved hood. You always tighten the nut at the slotted hole last. It allows that pin to move a bit as you bend the emblem.
Originally all the scoops were painted body color on the top, flat black primer on bottom for the same reason you black out behind the grille. With this exception: the is a V21 (fender tag option) that painted the hood and cowl like I painted my Dart Custom, but in organisol black - a kind of very lightly textured semi-gloss black. Hardly anybody still uses organisol except for 100 point concours restorations because if you get even a little wax on it while waxing the adjacent body color paint it will never be right again. That's why I did mine in gloss black 20 years ago. There is somebody here that uses a specific mix that looks almost identical to organisol without the draw backs. If you go that route - on a Sublime green car it sure would look wicked, especially with the trimmed hood edge!
