cudaracer
Headers! That cam wants headers.Without 'em you will be sacrificing 10 to 20odd horsepower at the peak, and torque through out the rev range.
Your Scr looks to be 8.22@165psi, probably too high even for 91gas, depending on your squish dimension.With a smaller cam, 10/1 may be too much.
>I'm not a fan of the thin headgasket.I also question the use roller rockers and, the use of that cam if you never rev it past 3500; both overkill in a 3500 engine. At that rpm the 268* is just waking up, and you have sacrificed the stout bottom end that comes from installing the proper cam for your intended useage. Also that cam will not be happy without help from a hi-stall TC and 3.23s is the lower limit for it.
That cam does not have a 30* ICA, more like 60* in at 106
Even a 2bbl 240 cam has an ICA of around 50*
>Here's how to figure the ICA:
360 plus (intake duration divided by 2, less the installed centerline) less the intake duration, less 180, change sign on the calculator,equals ICA
Example 1; 360+(240/2,-110),-240,-180,signchange=50*, for a 240*/114
Example 2; 360+(268/2,-106),-268,-180,signchange=60*, for a 268*/110
Example 3; 360+(292/2,-104),-292,-180,signchange=70*, for a 292*/108
>You're confusing me. Why are you building a 6500 rpm engine, to spin it only to 3500 and saddling it with handicaps like a stock convertor and 3.23s and too much compression? This is all messed up.And why the pre-occupation with how much power will it make if you never explore that power?
Here's an idea;Try to evaluate what you really want.
Pick one only, from each line, and highlight it.
Low-rpm cruiser.Tire fryer.
One gear bomber.Zero-to-60 screamer.
Punch it at 32mph and light up the tires.
This is a DD,or weekend bomber, or street/strip,drag-racer,other?
I care about what gas I have to burn;................. not a bit,some,a lot.
Cruising at hiway speed in comfort means to me; not a bit,some,a lot
I care about fuel mileage;................................... not a bit, some ,a lot
Then I,for one, will come out of confusion,hopefully.
Wow, so much good advice, from you and others. I forgot how much I love this site.
OK, so a bit of clarification on a few things first:
1. Comp cam card states powerband is from 1600-5800. Now, that is a bit higher than I wanted, but I already have the cam ready to go and don’t want another. Also, I have heard that combining a bit too much CR with a bit too much cam dials the extremes back, with respect to too much lope, too little vacuum, etc. Is this true? That is why I was targeting 10:1. And pumping 93 does not scare me, if that is needed.
2. 3.23 gearing is for now, but I might go a bit higher later.
3. Stock TC will be gone, looking to get around 2400 instead (forgot to mention).
As for what I am looking for, it is a weekend DD that I want the wife to safely be able to drive, but bark loud when I put my foot in it and burn rubber as needed. Oh, and most importantly, run what I brung and doing it all for dirt cheap.
