x block?The last 318 I built was bored .130 thou. It turned out pretty dam good. Kim
No, I used a 68/69 and a 70 block for the 3 I did. 68 and 70 were from darts and the 69 was from a coronet.x block?
WowNo, I used a 68/69 and a 70 block for the 3 I did. 68 and 70 were from darts and the 69 was from a coronet.
You are correct sir!I’m thinking it’s a pretty safe bet that NC EB won’t be attempting to bore a 318 block .130” for this build.
Does that mean 2.055's or 360 cast heads?Let me start by saying, I am definitely NOT a head porter, but the dilemma I'm pondering now, is that the speedmaster heads as cast, have the throat percentage to big for the 2.02 valve size for my liking, especially on a 322 cube engine. Theres not really a quick and easy way to fix that, so I'm gonna need to decide if I can live with that or come up with a alternative plan.
I'm not sure yet, but definitely no on the 2.05 deal and cast heads dont seem like the answer either, I'm weighing options currently. I kind of want to keep this build simple, something the everyday guy can assemble himself, nothing exotic, no crazy head porting or anything like that.Does that mean 2.055's or 360 cast heads?
Most everyday guy is gonna probably run it with stock size valves ported or not.I'm not sure yet, but definitely no on the 2.05 deal and cast heads dont seem like the answer either, I'm weighing options currently. I kind of want to keep this build simple, something the everyday guy can assemble himself, nothing exotic, no crazy head porting or anything like that.
I had high hopes of building a simple 318 with my 80's roller block and some Speedmaster heads. I have a steel 273 crank and the stock 318 cast crank. Or should I just put in a stroker crank and call it a day.I'm not sure yet, but definitely no on the 2.05 deal and cast heads dont seem like the answer either, I'm weighing options currently. I kind of want to keep this build simple, something the everyday guy can assemble himself, nothing exotic, no crazy head porting or anything like that.
Depends what the goal is, to me the reason to build a 350 - 450+ hp 318 is cause you want rpm, If your gonna stroke it, a 390 ish engine obviously can be bad ***, but I'd dig up a 360 block for a 408 why give up 18 cid if stroking $$$ for cid.I had high hopes of building a simple 318 with my 80's roller block and some Speedmaster heads. I have a steel 273 crank and the stock 318 cast crank. Or should I just put in a stroker crank and call it a day.![]()
I’m sure the majority of those heads are run in basically “ootb” form.I'm probably just gonna pretend like I didn't measure the throat and carry on!
I did that just to see on a stock 360. SM heads only went about 2 tenths quicker than stock 360 heads. And probably half a tenth was in weight. Again, my cam wasn't able to take advantage of the heads. I even used the stock stamped rocker arms.I’m sure the majority of those heads are run in basically “ootb” form.
What was the mph difference?I did that just to see on a stock 360. SM heads only went about 2 tenths quicker than stock 360 heads. And probably half a tenth was in weight. Again, my cam wasn't able to take advantage of the heads. I even used the stock stamped rocker arms.
I already have a roller block collecting dust. Either would be easy to build and get 400 horse. It's a underdog thing. Like putting it together with .030 flat tops and calling it a day. A decent fairly mild cam and 400 horse at the crank. Nothing wrong with that. No need for maximum horsepower.Depends what the goal is, to me the reason to build a 350 - 450+ hp 318 is cause you want rpm, If your gonna stroke it, a 390 ish engine obviously can be bad ***, but I'd dig up a 360 block for a 408 why give up 18 cid if stroking $$$ for cid.
Those 340's are magical. Bore to stroke combo? They work best with big valve heads. Just think about what happened in 72 with the small valve heads, cam, and the like.We just made the same torque with much better power with a stock stroke 340 a few weeks ago
If I remember correctly, 2 mph. 60 ft stayed the same as cast headsWhat was the mph difference?
