Thanks. Mains were torqued and the crank spun nicely. #1 and 2 pistons felt tight, but then again I don’t know how tight it should be. I thought I could be efficient and install all pistons after 1 and 2 went in, then torque. I’m going to take everything apart tomorrow and start over.
The rods were checked for straightness at the shop prior to install, so I don’t think it’s a bent rod. The rings are supposedly pre-gapped, but I will double check tomorrow. The space between caps is .002, and the space between rod caps/main caps is .0015 to 002. I’m not sure what the specs are, need to check.
Is there such a thing as using too much assembly lube on bearings? I gobbed it on pretty good, thinking excess would squeeze out.
Also, does anyone know if the journal widths are different from the 71 to the 73 crank?
