right?Because it’s not the same money when you don’t have a 360 to start with. I don’t care if the next Magnum at the yard is a $100.
i woudnt take a 625 for free well i guess i would and sell it i hate those pos carbs ma mopar dropped the ball with that pos on the 340right?
let's say a 5.9 drops in your lap?
so, you've got a cam re-grind at what? $250, gaskets & seals let's call that $150, intake? let's stay cheap with an offshore unit at like $175 and choose your own adventure with a carb, and since we're cheap, why not a swapmeet special eddy/carter 625 for a princely $100
all off that you need. there's $675.
oh, and throw another $150 for the flexplate, how about a car oil pan? let's do that kit from mancini that you get a pick up and dipstick with, there's $130. oh, and a magnum doesn't have a fuel pump provision. so reuse your old cover with the hughes adapter for $30 or cough up for a pump. duh, we need an oil pump and timing chain, there's another $200 out the door.
okay, i think we've got most of the parts and we're at 1185, that we can call 1200 all day. so let's add $200 in budget overrun for whatzits, thingamajigs and doohickeys. and tack on another, $200 for tax, shipping, and general skull duggery.
$1600
this surmises everything in the motor is useable. and you can reuse major components from your existing small block- distributor, motor mounts (maybe), exhaust, accessories.
how far does $1600 go on a 318 that you have, is known to be in good working order and is reasonably outfitted?
Oh definitely following others successfully builds is a good thing, not knocking it.There’s a bunch of people viewing these pages that don’t know and are reading up on how to do stuff. Not knowing is OK. Pretending to know, (Not you 273) is another thing. So, reading a recipe or doing a copy cat build (no shame there!) is a great way to get going faster.
I fully endorse anyone that isn’t sure on the route to take with there engine to copy someone else’s, follow a recipe from a book, or just have someone build it for them.
No shame, no harm, no foul.
Go get tinkering and build a beast, no matter what HP level you’re after. Simple rebuild? Go for it! Mild hop up? Go for it! Trying your hand at a street strip machine? Go for it!
No doubt!
Wooo-Hoooo!!!! My fav sb street engine.right?
$1600
I doubt it can happen longer than 5 minutes. I get over crap really quick and laugh about it. Hopefully, someone else here will do the same IF there pissed off.Hope i never make rumble mad
That's my favorite of his cars I was born in 70 and nhra was on tv every weekend and i still love bob just the best.. i would like to try something with a short stroke and stupid high RPM but i worry too much and try to stay under 6k..I have a question!!!!!!
What if someone wants the challenge of going fast with a 318?
Or smaller engine?
What if there in a class with cubes per pound of car?
You get weight breaks with smaller engines.
This was a thing years back for sure. I don’t know about today.
Bob Glidon used a small displacement MoPar for a bit with ridiculously crazy ported W2 heads. Won the championship with that small engine. IIRC…..
Oh I hear ya!I have a question!!!!!!
Or smaller engine?
To me there's two main way to look at a build, build for X power or Y rpm, to build for X power these engines are generally gonna take the same parts but the 318 needs more rpm gear stall etc..Why do these always turn into:
A- don't do anything to a 318, because it's useless, unless....
A lot of people have vague goals/wants leaving discussions wide open and sometimes it's easier to argue the exaggerated to prove/make your point.B- change the heads, install a 4000 RPM converter, change the bore, install a .700 lift cam, and 5.13 gears.
It's where I too see the dividing line, especially in the 340/360 cid area. Above this you start to see peak torque really move up in rpm trading low for top. Below this you generally don't see too much change in the 2500-3000 rpm or so range and overlap is generally still fairly tame even at narrower lsa.@AJ/FormS
Awesome thread my man.
Come back with da-facts again.
I like your cam @220 for nice street performance thoughts. I agree very much. Enough duration as to not make a low end pig and enough to wind it up some.
Oh ****, almost forgot……right?
$1600
When I first started on this site my goal was to build my rusty 65 Cuda into a Time Attack car, we have a fairly big road course near by Mosport Park guess it's called Canadian Tire Motorsports Park now.I have a question!!!!!!
Or smaller engine?
Yeppers, didn't workout car is gone, I haven't 100% decided but probably want the Valiant to be able do 1/4 and parking lot atuox, know it's complete opposite suspension setups, still got the suspension upgrades I bought for the Cuda. Definitely 1/4 mile this year.I remember you had a thread on that also titled “Time Attack” didn’t you?!?!
A 1/4 mile and autoX?Yeppers, didn't workout car is gone, I haven't 100% decided but probably want the Valiant to be able do 1/4 and parking lot atuox, know it's complete opposite suspension setups, still got the suspension upgrades I bought for the Cuda. Definitely 1/4 mile this year.
HR Cat says: hello. thank you for coming, please take a seat. we have to talk...Well, being that there are many ways to skin a cat...
Yup, must have the 27 8 × 10 glossies with circles and arrows.What no pictures or graphs?
You can have anything you want, - at Alice’s restaurant!Yup, must have the 27 8 × 10 glossies with circles and arrows.
Nothing wrong with teens as a base to work with. Yup the open chamber heads are prone to detonation if the SCR is raised to 10:1. Now ask why? The quench of closed chamber heads provides mixture motion in the combustion chamber at TDC to aid a quick burn, to be complete before cylinder pressure and temperature rises high enough to cause any unburned air/fuel to autoignite. This can be allieviated at least to some degree by port and bowl porting on the cylinder wall side to generate swirl. You do have to exercise caution or get access to a sonic thickness tester so you do not get into the cooling system.I'm using trickflows on mine, with a howards roller.. CR should be 9.6:1 ish.. i might just scrap it now to find a 340 after this thread.
How many on here remember or know of that these days?You can have anything you want, - at Alice’s restaurant!
Walk right in it’s around the back - just a half a mile from the railroad track -
You can get anything you want - at Alice’s restaurant….
Basically you are speaking of advancing the cam. You do have to watch piston to valve clearance as you advance the cam. "RV cams" had a bit more duration and lift and installed generally with no difficulty. Now add to that a .1 increase in rocker ratio, you will also benefit torque across the RPM band. As with any change in cam and valvetrain the PV clearance must be checked.Couldn't you have a performance cam with stock IVC to keep stock V/P or even closes sooner for better V/P and go somewhat wilder on the other dimension and have best of both world?
