That's awesome! Thanks for sharing. Love that poly.Here is article from Chrysler Power Magazine on my build
The 2-bolt Australian valve covers thru Craig Fountain can be purchased still just contact him thru email [email protected]For the guys interested in that manifold, you might contact Gary Pavlovich since he was in regular contact with Roland Osborne who was apparently spearing heading that effort. I know Roland passed away and the manifold production stopped. Possibly the tooling still exists that this could be resurrected on both the manifold and valve covers. There are also valve covers available through an Australian fellow named Craig Fountain.
Is Pavlovich still doing poly stuff? I’ve looked and asked for contact info a couple of times with no success.For the guys interested in that manifold, you might contact Gary Pavlovich since he was in regular contact with Roland Osborne who was apparently spearing heading that effort. I know Roland passed away and the manifold production stopped. Possibly the tooling still exists that this could be resurrected on both the manifold and valve covers. There are also valve covers available through an Australian fellow named Craig Fountain.
I think he is "Semi-retired" from the business but is 100% involved still as an enthusiast. He is generally on the Poly 318 group on FB from what I'm told. Or: [email protected]Is Pavlovich still doing poly stuff? I’ve looked and asked for contact info a couple of times with no success.
Sending you a DMIs Pavlovich still doing poly stuff? I’ve looked and asked for contact info a couple of times with no success.
The pushrod angles are much nicer in the Poly/LA block with poly heads.
Once you fit an LA head the angles are quite odd indeed.
Only rectified with R5 blocks I believe 59 degrees and 49 degrees?
