Most likely stick, I dont have a spare stick and have plenty of autos but I like to shiftis it a stick or auto
Ill have to find a stick, got the pedals and bellhousing and most other things.
Did the truck come originally with a stick?
Personally i would go auto with a mild stall converter say 2200-2500 rpm
Glad you asked, I called federal mogul today and they told me that I could easily/safely remove 100.000 from the top of the piston if I chose, he also told me 7.6 for valve relief CC ( if I remember correctly, I left the exact info at the shop )What bore diameter are you putting into the head gasket?
Have you looked up them piston to see how many cc dome/dish(above/below deck cc they have????
Sorry for the confusion and the way Im approaching this.... anyway my buddy cant turn the pistons in his lathe accurately bu someone else I know has a special fixture ( havent seen it yet ) that he loaned to a buddy of his that Ive contacted and am on my way out there now.
He will do all 8 for 50 bucks, he evidently owes the guy that has lent him his tool.
I know there prob isnt time to get an answer right now so Im gonna drop them off and then tell him Ill get back with him to tell him how much to remove.
I want to get the block squared that means taking off .020 thou, the highest one is sticking out the hole .020 ( approx ) so that means according to whats been given above that I should have no more than .015 taken off the piston unless Im mistaken.
That will let me run a standard head gasket and I wont have to be worried about intake/head sealing issues.
I look forward to response
You mean 100 thousand aka .100"
Like i said before, while you're doing you measurements keep quench in mind.
You can check the bore diameter on the head gasket you took of for reference.
With a .060 over bore 340 (4.100) i think you need to stay with a 4.180 bore gasket. i don't think a 4.04 bore gasket is a good idea. WHAT SAY YOU ALL...............
Now onto the valve reliefs. that tells you how much to subtract from a .018 pop up flat top right? You need more math to so see how many cc a flat top piston would be .018 out of the hole........or .020 out of the hole for you tallest piston......Make sence?
I will try and dig it up and lay it out for you.
OK here is the math. you don't have to understand the math to use it!
.7854 X bore X bore(4.100 x 4.100) x stroke aka piston pop up(.018") = 0.2376463(cubic inch) X 16.387(converts it to CC)=3.8943099 or 3.89CC
So your piston sticking out of the hole as a flat top(no valve reliefs)=3.89 cc
Your Valve reliefs are 7.6 CC, Sooo, 3.89 CC (Minus) -7.6 valve relief CC equals a minus (-)3.70569 or 3.71 CC in the hole.
Good cause I do not understand it
So when you use that calculator and it says (Input a positive number for valve reliefs.
Input a negative number if it has a dome. )
It has a .018" dome or pop up but it is actually in the hole 3.71 CC not 7.6 CC aka you us "positive number" on the calculator, not a negative number. Even though the math we just did cam up with a negative number.
compression is volume below piston (stroke)+ volume above piston, divided by volume above piston.
You add 3.71 cc to the head volume. if it had a dome that stuck into the combustion chamber, then there would be less space in the combustion chamber causing you to us a negative number.
If i lost you anywhere, let me know and i will try to explain better.
Note: I used the .018" pop up or above deck because what's what the piston manufacturer said it is.
I just when and played with that compression calculator.
didn't realize it had deck height on it.
compression come out the same if you use 7.6 and deck height -.018"
or if u use my math above and input 3.71 and then .000 deck height.
Wow that was a lot of hot air for nothing![]()
Stop!
back up the bus.
This has already been mentioned, but it is worth repeating; Your deck height may vary because the rods vary. Or because the crank is not the same stroke on every throw.Or because one deck is shorter than the other, or because one or both decks is not running parallel to the crank. If you square deck it you have paid a lot of money, possibly to not correct anything at all. Before spending money, you have to prove whats what.
Here's how to prove it in your garage;
Drop the crank in with just the front and back main-bearings,snug up the bolts to like 80% torque, no big deal. Get a Sharpie. Grab any piston and rod assembly.Drop into #1 hole with a new top-half bearing. Set it just below the deck. Lay a STRAIGHT square rod across the hole on it's centerline in the fore/aft direction, on the wrist pin axis. I use a 1/4sq by about 8" length of keystock. Set your dial indicator up on it, set to zero. Now roll the crank over to push the piston up out of the hole. The piston will raise the bar and the indicator will read the deck-height. When it peaks, stop. Rock the piston and record the MINIMUM height.Write it on the deck with the Sharpie on the valley side of the hole.
Repeat in every hole with this same piston assembly.
Now you have a picture of where the decks and crank-throws really are! You will find some tall deck heights and some short heights.
Now,number your cylinders 1 thru 7 on the drivers side and 2 thru 8 on the passenger side, in proper Moparese. Find the cylinder with the tallest deck height. What ever the number of that cylinder is, mark the top of this piston assembly with that number and the deck height in that hole,and set it aside.
Next grab another assy and stick it in this same hole. Measure it's deck height. Mark the top. Repeat with each of the other assys.
Now, line those assys up from tallest to shortest. You know where this is going right?
Take the longest assy and mark it with the number of the shortest hole. Then the next longest, gets the number of the next shortest hole and so on.
On a separate sheet of paper, right down all these things you have discovered, using the stamped number on the rod, as a reference. Record also the number of the tallest deck ht with what rod # was used, and what rod ended up in what hole. The important thing is to be able to identify the various deck-heights by the rod number, so that when the Sharpie IDs get erased, you can still find what assy goes in what hole.
Ok
Finally, stick each one in it's designated hole and measure it's deck height, in it's new hole. Erase all the old numbers. Mark it with the number of the HOLE on the top now, and the deck height in that hole.
Make a map like the one you earlier made but now with the holes correctly numbered in the Mopar way. Record all the final information, and what rod goes in which hole.
You might be concerned with what happens if you separate the pistons from the rods.And I was too. I found tho, that the piston tolerances are extremely well managed with differences in compression heights almost negligible.
So after you get this far, you will want to restamp your rods, to make it easier to correctly locate them at some future rebuild/freshening.
Now if you actually perform this exercise, you may find the deck-height variance to be acceptable. I got mine to within 002/003 IIRC.
If you get yours this close, then the block can be left alone.
At this point, you can shave the tops off the pistons equally to achieve your very-tight Q. I run .034 in my 367 with those same heads and rods but with KB hypers. The machine shop that I trusted, opened up the skirt clearance to .003/.004. Boy was I mad. This is partly why I run a minimum water temp of 205*, that's another story.
Now back to your post, above. If you square deck your engine, and it comes back perfect, but your crank is goofy and you have eight different length rods, you may actually be making things worse, cuz you have lost the opportunity to use the crooked block to your advantage. Only careful measuring can prove the block will or will not, work,......as is.
One more thing to think about;This is the best time to check the fit of your intake flanges to the heads to the decks. If it too is messed up, then the sq-decking is back on the table.
To do this, you can set the clean heads on the clean decks and snug down just the four corners, of each head, no gaskets. Drop the intake on. Measure the valley gap to the nearest 1/16 or so, and find some straight bar stock to lay on the china-wall to elevate the intake and produce a gap at the intake gasket surfaces. Drop the intake back on and skate it over to one side. Push it up tight and eyeball the fit where the gasket should be. If you see a gap, stick a feeler gauge in it. Check the front then the rear. Then slide it over to the other side and repeat. If there are gaps, you might be in trouble. If the gaps are on the bottom, it will never seal. The running engine will pull in oily crankcase vapors and fog the neighborhood, and it will run like crap. A slight gap at the top may be permissable, depending on how many corners are standing open, and how you are able to torque it down to average them all out.
So now you have, possibly, a second reason to SQ-deck.
