340 build
This has already been mentioned, but it is worth repeating; Your deck height may vary because the rods vary. Or because the crank is not the same stroke on every throw.Or because one deck is shorter than the other, or because one or both decks is not running parallel to the crank. If you square deck it you have paid a lot of money, possibly to not correct anything at all. Before spending money, you have to prove whats what.
Here's how to prove it in your garage;
Drop the crank in with just the front and back main-bearings,snug up the bolts to like 80% torque, no big deal. Get a Sharpie. Grab any piston and rod assembly.Drop into #1 hole with a new top-half bearing. Set it just below the deck. Lay a STRAIGHT square rod across the hole on it's centerline in the fore/aft direction, on the wrist pin axis. I use a 1/4sq by about 8" length of keystock. Here is where I am a bit confused, to confirm you use a 1/4 by 8 inch length of keystock? So you have it laying on top of the deck over the piston, is that correct? Set your dial indicator up on it, your saying here to put my dial indicator on top of this piece of keystock? set to zero. set to zero ok but where is the pointer resting, on the keystock, on the deck, on top of the piston? Now roll the crank over to push the piston up out of the hole. What if the piston is still below the hole like my 440 is? What then? The piston will raise the bar and the indicator will read the deck-height. Ok so it sounds like you want the dial indicator on top of the keystock and the pointer or plunger of the dial indicator on top of the deck? When it peaks, stop. Ok so it sounds like once again you are measuring how far the piston is rising above the deck. Rock the piston and record the MINIMUM height. Im sorry but Im confused, Im more of a visual guy, what do you mean minimum height? Write it on the deck with the Sharpie on the valley side of the hole.
Repeat in every hole with this same piston assembly. I will do this for sure
Now you have a picture of where the decks and crank-throws really are! You will find some tall deck heights and some short heights.
Now,number your cylinders 1 thru 7 on the drivers side and 2 thru 8 on the passenger side, in proper Moparese. Stupid question but are all mopar engine ( typical mopar engines ) from the 60/70s have the same cylinder order, it is the same as firing order correct ? Find the cylinder with the tallest deck height. No problem I can do this once I understand whats written above What ever the number of that cylinder is, mark the top of this piston assembly with that number and the deck height in that hole,and set it aside. Ok its getting tougher to visualize since Im not clear on the first few steps
Next grab another assy and stick it in this same hole. Measure it's deck height. Mark the top. Repeat with each of the other assys.
Now, line those assys up from tallest to shortest. You know where this is going right? I do have a vauge idea of what your doing and I like it. Im gonna have to wait I think to go any further. I need to understand the first steps better.
Take the longest assy and mark it with the number of the shortest hole. Then the next longest, gets the number of the next shortest hole and so on.
On a separate sheet of paper, right down all these things you have discovered, using the stamped number on the rod, as a reference. Record also the number of the tallest deck ht with what rod # was used, and what rod ended up in what hole. The important thing is to be able to identify the various deck-heights by the rod number, so that when the Sharpie IDs get erased, you can still find what assy goes in what hole.
Ok
Finally, stick each one in it's designated hole and measure it's deck height, in it's new hole. Erase all the old numbers. Mark it with the number of the HOLE on the top now, and the deck height in that hole.
Make a map like the one you earlier made but now with the holes correctly numbered in the Mopar way. Record all the final information, and what rod goes in which hole.
You might be concerned with what happens if you separate the pistons from the rods.And I was too. I found tho, that the piston tolerances are extremely well managed with differences in compression heights almost negligible.
So after you get this far, you will want to restamp your rods, to make it easier to correctly locate them at some future rebuild/freshening.
Now if you actually perform this exercise, you may find the deck-height variance to be acceptable. I got mine to within 002/003 IIRC.
If you get yours this close, then the block can be left alone.
At this point, you can shave the tops off the pistons equally to achieve your very-tight Q. I run .034 in my 367 with those same heads and rods but with KB hypers. The machine shop that I trusted, opened up the skirt clearance to .003/.004. Boy was I mad. This is partly why I run a minimum water temp of 205*, that's another story.
Now back to your post, above. If you square deck your engine, and it comes back perfect, but your crank is goofy and you have eight different length rods, you may actually be making things worse, cuz you have lost the opportunity to use the crooked block to your advantage. Only careful measuring can prove the block will or will not, work,......as is.
One more thing to think about;This is the best time to check the fit of your intake flanges to the heads to the decks. If it too is messed up, then the sq-decking is back on the table.
To do this, you can set the clean heads on the clean decks and snug down just the four corners, of each head, no gaskets. Drop the intake on. Measure the valley gap to the nearest 1/16 or so, and find some straight bar stock to lay on the china-wall to elevate the intake and produce a gap at the intake gasket surfaces. Drop the intake back on and skate it over to one side. Push it up tight and eyeball the fit where the gasket should be. If you see a gap, stick a feeler gauge in it. Check the front then the rear. Then slide it over to the other side and repeat. If there are gaps, you might be in trouble. If the gaps are on the bottom, it will never seal. The running engine will pull in oily crankcase vapors and fog the neighborhood, and it will run like crap. A slight gap at the top may be permissable, depending on how many corners are standing open, and how you are able to torque it down to average them all out.
So now you have, possibly, a second reason to SQ-deck.
Comments inside the Quote,click to expand
Drop the crank in with just the front and back main-bearings,snug up the bolts to like 80% torque, no big deal. Get a Sharpie. Grab any piston and rod assembly.Drop into #1 hole with a new top-half bearing. Set it just below the deck. Lay a STRAIGHT square rod across the hole on it's centerline in the fore/aft direction, on the wrist pin axis. I use a 1/4sq by about 8" length of keystock. Here is where I am a bit confused, to confirm you use a 1/4 by 8 inch length of keystock? So you have it laying on top of the deck over the piston, is that correct?YES Set your dial indicator up on it, your saying here to put my dial indicator on top of this piece of keystock?No just the pointer; the base goes on the deck, same as you already did set to zero. set to zero ok but where is the pointer resting, on the keystock, on the deck, on top of the piston?On the keystock Now roll the crank over to push the piston up out of the hole. What if the piston is still below the hole like my 440 is? What then?This is just for pop-ups The piston will raise the bar and the indicator will read the positive deck-height. Ok so it sounds like you want the dial indicator on top of the keystock and the pointer or plunger of the dial indicator on top of the deck? heh-heh, That would be quite the balancing act; but it would sorta work, I guess. When it peaks, stop. Ok so it sounds like once again you are measuring how far the piston is rising above the deck. That's right. We want to know the exact positive deck height, for the next steps. We need more than about this or about that. Rock the piston and record the MINIMUM height. Im sorry but Im confused, Im more of a visual guy, what do you mean minimum height? When you rock the piston ,the pointer might rise a half a thou or thou, and artificially increase the deck height. you don't want that,you want the lowest number. Write it on the deck with the Sharpie on the valley side of the hole.
Now,number your cylinders 1 thru 7 on the drivers side and 2 thru 8 on the passenger side, in proper Moparese. Stupid question but are all mopar engine ( typical mopar engines ) from the 60/70s have the same cylinder order, Mopar numbers their pistons from front to back ON THE CRANK, So the first piston is on the drivers side front and the last is on the passenger side rear. it is the same as firing order correct ? No,SBMs are 1-8-4-3-6-5-7-2 Find the cylinder with the tallest deck height. No problem I can do this once I understand whats written above What ever the number of that cylinder is, mark the top of this piston assembly with that number and the deck height in that hole,and set it aside. Ok its getting tougher to visualize since Im not clear on the first few steps. Yeah, sorry,but it will be worth it in the end.
Next grab another assy and stick it in this same hole. Measure it's deck height. Mark the top of the piston. Repeat with each of the other assys.
Now, line those assys up from tallest to shortest. You know where this is going right? I do have a vague idea of what your doing and I like it. Im gonna have to wait I think, to go any further. I need to understand the first steps better.
Ok
Now back to your post, above. If you square deck your engine, and it comes back perfect, but your crank is goofy and you have eight different length rods, you may actually be making things worse, cuz you have lost the opportunity to use the crooked block to your advantage. Only by careful measuring can prove the block will or will not, work,......as is.
To do this, you can set the clean heads on the clean decks and snug down just the four corners, of each head, no gaskets. Drop the intake on. Measure the valley gap to the nearest 1/16 or so, and find some straight bar stock to lay on top of the china-wall to elevate the intake and produce a gap at the intake gasket surfaces. Drop the intake back on and skate it over to one side. Push it up tight and eyeball the fit where the gasket should be. If you see a gap, stick a feeler gauge in it. Check the front then the rear. Then slide it over to the other side and repeat. If there are gaps, you might be in trouble. If the gaps are on the bottom, it will never seal. The running engine will pull in oily crankcase vapors and fog the neighborhood, and it will run like crap. A slight gap at the top may be permissable, depending on how many corners are standing open, and how you are able to torque it down to average them all out.
Ok thanks, is there really so much that has to be changed to do this procedure for a piston that is below deck, like I had mentioned the 340 is already at the machine shop, its tough to find a good machine shop in this area, they know they are good and they are gonna tell me to go pound sand if I ask for my shiz back to make some measurements.
Id like to not make another mistake on another engine so Id like to learn the procedure on the 440 which is the only other engine I have avail to me now.
Seems like its prob. something simple that could be changed within your procedure to make it work for a piston that is below deck but you tell me, maybe it just isnt that easy
Seems like its prob. something simple that could be changed within your procedure to make it work for a piston that is below deck but you tell me, maybe it just isn't that easy
It is easy;real easy. Just put a spacer of known thickness on top of the piston, in the very center, that is thicker than the negative deck height. Then after measuring the new positive deck height, subtract the spacer height and Presto! there it is; the negative deck height to at least two maybe three decimal places.
For example;
If your pistons look to be .150" down in the hole. You put a spacer on there that is exactly .250 thick. You measure the deck height in the normal way with the keystock spanning the center of the hole on the wrist-pin axis. You measure it to be .098 up. Then you subtract the spacer thickness from that and get MINUS .152. Your piston is down in the hole .152 inch. Minus means down in the hole.
If you had used a .200" spacer, the deck ht would have measured .048, and subtracting .200 from that would get you MINUS .152, same number.
Down in the hole is not automatically a bad thing.
Ok I figured it would be simple, I need to get back to the post again when I have a chance, re-read and Im sure have more questions cause again god forbid I make anything simple.
Ok the cam is held in place by the front cam plate. This limits the fore and aft movement. It has hit every exhaust valve. Which is the most likely valve to hit. The piston is chasing the exhaust valve as it is closing. The terms for the chambers are open and closed chambers. You have closed chamber heads. These are open chamber. The chamber has a round recessed area and is production 340 x head
Also I would not use wire wheel on aluminum. It cuts into the metal. Careful on the deck surface of the block too. I carefully use red 3m scrubby by hand.
Thanks for the tip and I see the difference now in the heads
Your closed chamber heads are nice because after you figure out where the piston is you can get a head gasket that will give you quench. The two flat areas on your heads when about .035 from the top of the piston squishes/quench the mixture towards the plug and helps it remain mixed. With the right compressed head gasket thickness the closed chamber head is easier to get quench.
Unfortunately my yahoo mail is down, I cant receive or send any messages including private conversation messages so Ill just post a question here for A/J and look like a dumbass to everyone.
BTW I get a temporary error 2 on my yahoo mail since last night if anyone can wave a magic wand and fix that it would be appreciated
Im trying to put the steps he gave into an order I can take over to the engine and perform, Ive got this so far :
1- Put the crank in with just the front and back main-bearings, snug up the bolts to like 80% torque, not critical. Grab a sharpie a Sharpie.
2- Get any piston and rod assembly and place into #1 hole with a new bearing installed. Remember to protect the crank by placing a short piece of hose over the rod bolts.
3- Set the piston just below the deck if the piston typically sits above the deck when fully extended.
4- Lay a STRAIGHT squre piece of metal across the hole ( across the top pft he piston ) sitting on top of the deck on it's centerline in the fore/aft direction, on the wrist pin axis.
5- Set your dial indicator up on top of the deck with the pointer resting on top of the center of the keystock.
6- Now roll the crank over to push the piston up out of the hole. The piston will raise the bar and the indicator will read the positive deck-height.
What I dont get at this point is why do I need to lay the metal across the bore or across the top of the piston and measure how far up off the deck the metal is pushed, why cant I just zero out the piston at the top of the deck by fastening down a piece of straight metal across the top of the deck and across the top of the piston like I have done in previous pictures and then remove the metal and then set my dial indicator on the deck with the plunger sitting in the center of the piston and then measure how far further up the piston comes out of the hole?
2 - Get any piston and rod assembly and place into #1 hole with a new bearing installed. Remember to protect the crank by placing a short piece of hose over the rod bolts.
3 - Set the piston just below the deck if the piston typically sits above the deck when fully extended.
4 - Lay a STRAIGHT squre piece of metal across the hole ( across the top pft he piston ) sitting on top of the deck on it's centerline in the fore/aft direction, on the wrist pin axis.
5 - Set your dial indicator up on top of the deck with the pointer resting on top of the center of the keystock.
6 - Now roll the crank over to push the piston up out of the hole. The piston will raise the bar and the indicator will read the positive deck-height.
7- Write on the deck with the Sharpie on the valley side of the hole how far the piston is either down in the hole or sticking out of the hole.
8 - Repeat in every hole with this same piston assembly and hwne this is done you will have a picture of where the decks and crank-throws really are! You will find some tall deck heights and some short heights.
9 - Number your cylinders 1 thru 7 on the drivers side and 2 thru 8 on the passenger side, in proper Mopar fashion, first piston is on the drivers side front and the last is on the passenger side rear
10 - Find the cylinder with the tallest deck height, whatever the number of that cylinder is, mark the top of this piston assembly with that number and the deck height in that hole,and set it aside.
11 - Next grab another piston assy and stick it in this same hole. Measure it's deck height. Mark the top of the piston. Repeat with each of the other piston assys.
12 - Line those assys up from tallest to shortest.
13 - Take the longest assy and mark it with the number of the shortest hole. Then the next longest, gets the number of the next shortest hole and so on.
This is as far as Im gonna go for now, Im gonna go out and try to perform these steps
No reason that you cannot do it this way with pistons that pop above the deck.
The whole point here is to:
- Measure the compression height of the same piston/rod assembly in each hole to find out the total variations compression heights due to the deck variations AND the crank variations.
- Then, put all of the piston/rod assemblies 1 at a time into the same hole, and measure the compression height variations. This 2nd step allows you to ID the variation in length due to JUST the variations in rods and pistons.
- Once you have both sets of data, then:
-- You marry up the shortest piston/rod assembly(lowest compression height found in step 2) to the hole that gave the tallest compression height in step 1.
-- And then the tallest piston/rod assembly can be married to the hole that gave the lowest compression height in step 1.
--Then you try to match the intermediate compression height piston/rod assemblies into the middle height holes.
This is all to to try the get the compression height variations minimized. If the total compression height variations are down to .005" versus a .010" overall compression height variation, then you have decreased the compression ratio variation by about .1 point. You won't feel this in engine operation or performance directly, BUT it allows you set the quench gap more closely and accurately IF you have closed chamber heads, and you want to optimize quench and its improvements in detonation resistance.
If you have an engine with open chamber heads, you won't have a quench gap, so this procedure is a bit of a waste of time for open chamber heads IMHO.
AND, if you have an engine with stock type pistons, with notches on the piston tops that point towards the front of the engine, you are not supposed to swap pistons side to side in the engine. These pistons have what is called 'pin offset', where the pin is not centered between the thrust faces of the pistons. This pin offset is for smoother engine operation, and the offset goes one way on the passenger side, and the other way on the driver's side. Pistons like the TRW/SpeedPro forged units that are in the 340 discussed here don't have offset. Most performance aftermarket pistons don't have any pin offset either.
Thank-you for the clarification. What would you call the procedures given above, just for the heck of it I googled indexing pistons/connecting rods and cam up with nothing. I keep a binder with all of this sort of information and Id like to not only put a title to it but Id also like to see the various ways others have done it and the results they achieved that have been documented over the net
two reasons
1) By removing and reinstalling the indicator you may introduce a new accidental error, and
2) your way is waaay more work,lol
Your method may work, but I like the KISS way. My way, the usual way is a one-step deal with no accidental errors introduced. If you are gonna blueprint the deck heights like this, Your way is gonna burn thru a lot of time.
BTW; to prove your sq bar is straight, measure its height on each of it's 4 faces. It should measure the same.
Also, when the piston comes up to the keystock, it has to hit the key with the highest point of the piston, which may not always be right above the wristpin. This is not real important in your case as you have plenty of piston to head clearance in that area. More important for you will be the flat area , the quench pad. Unfortunately, trying to keep that area parallel to the deck surface will be tough as the piston rocking motion will try to mess up your measurements. That is why I use the area above the wristpin, cuz it will exhibit the least change with the rocking of the piston.
two reasons
I understand your thinking, what Ive done is ordered a deck Bridge like the one I show here, I think its gonna be a real time saver and Ive had need for one a few times in the past anyway.
