I'd buy a new one, with faster lobes, and more lift.
225@050 is a very nice street cam.But the 273 will want a lot of compression to not be soft on the bottom; unless you already have something like a 3000TC, and at least 3.55s.If you have those, then you can sacrifice some Dcr and the 273 will have a little lope in it if you idle it way down.
At .325 lobe lift or .488 with 1.5 true ratio, it will play nice with stock LA guides.
At 273* and with an auto, it will want to be shifted quite deep, so springs will be need to to be selected to go there, and that will put the pressure on those reground lobes. With a stick-car you could shift a good 300rpm sooner.
Still it's hard to justify risking a tear down for $60.
Those are my thoughts
