bobscuda67
Due to some great weather last weekend I have my engine stripped down ready to pull the cam.
I think I can pull it out with out removing the grill.
It has a XE 274 and it's not working, thanks Comp Cams tech line.
What I have is a 340 with a 3.58 stroke and stock rod.
It has a measured 9.9 static compression ratio.
Magnum heads with stock valve 120 seat and 300 open spring pressure. Also 1.6 roller rockers.
AirGap with a 650 carb.
Not so good is I'm using 340 exhaust manifolds with 2 1/4 inch dual system.
And a 2200 stall converter with a 3:55 rear gear. The 904 trans has a low gear set with a 26 inch tire.
I'm thinking about 4 different cams.
Lunati Voodoo 256. 8.26DCR
Lunati Voodoo 262. 8.03 DCR
Comp XE 262. 8.21 DCR
Hughes SEH 1620. 8.54 DCR
This is street only of course and the torque curve is the most important thing to me.
Should I try and keep the DCR as high as I can or is it not that important?
Does it even make any difference?
