skep419
5.9 Magnum 4 speed afficionado
We're all at hogwarts learning magic. Comp cams aka Lord Voldemort............
This is great stuff
Looks like you're referring only to seat duration specs when looking at overlap, which will tell you when there is .006" of valve lift having a negative effect on vacuum. Think hard now, how much do you actually suppose this amount of valve lift effects things? It isn't very much
This is the main reason why the common spec of "0.050" exists. it is used as a point of reference where it can be considered that valve lift actually starts to perform it's function, allowing gases from the intake runner to enter the cylinder and for pressures between the two to equalize.
Put in simpler terms, how long the valve overlap period occurs can be seen with duration numbers alone. But how far they are open requires both seat duration AND duration @ .050"
We know that more degrees of overlap will reduce vacuum.
We also know that you lose more vacuum through a big hole than a small hole (like a completely open valve compared to a nearly shut valve. for an extreme example)
So if we have two camshafts with the same degrees of overlap as measured by seat-to-seat specs, but one having more overlap at 0.050". The one with more degrees of overlap @ 0.050" is reaching higher valve lifts earlier as they open and keeping them open for longer as they are on the closing side of the ramp, even if the total duration is the same. Since overlap happens at the beginning of one valve and the end of the other, this is an important factor.
Even with the same seat duration, a higher spec @ 0.050" will have the valves be open FURTHER during the overlap period and as such will have less vacuum at idle.
Uh no. When I calculate overlap. I use the valve events. That's how overlap is calculated.
Obviously you missed the entire point of my post. And it is this.
20-30 years ago - big duration/lift = late valve events = **** idle, **** streetability, **** daily driver.
Today - big duration/lift =/= late events =/= **** idle, **** streetability, **** daily driver.
Cams have come a long way in the last 20/30 years. You can have a bigger duration cam, with more lift, with better valve events. And that makes them street able, compared to the cams of past.
Gotta remember that cam designs are much better now. Valve events and such aren't nearly as drastic compared to duration/lift as they once were. For example. Look at the mopar P4120655 cam. 252 @ 50 duration. 110 LSA. Yet the overlap is 76. Very similar duration to the hughes. Yet much higher overlap. And lift is down!
It's definitely possible. For example. Looking at hughes STL5054AS-8. It has 250/254 duration. 108LSA. Guess what the overlap is? 66. Very mild compared to the duration. My XE274H has an overlap of 60. And it's 230/236 duration with 110LSA.
Then install the ****** 4-6* ahead. What don't you get? What I'm saying is exactly what you are either too stupid to understand or you don't want to LEARN.
We are talking two cams with relatively low overlap. If you can't make a 284 MP idle and be streetable you need to quit and go golfing.
You still have NOT explained why I can use 255 at .050 and get idle and vacuum that YOU can't? I posted my numbers. It's even on a 105 LSA. That's at least 5* ahead of what you think is the greatest thing since pussy.
Cams have come miles and miles and it's stupid to contend that a ******* passenger car head needs anything wider than a 108 is pure ignorance. And YOU continue to preach ignorance. Youre so ate up by the numbers that you can't see the numbers. ******* crazy.
Now I'm going to post WHY comp, the crap company that it is, decided 110 LSA was the best thing since pussy and it had ZERO to do with performance.
As comp grew in size to the monolithic sloth it is today, they had to do what crane had already done...own a company that made cores. If you are grinding cams at the rate comp does, you can't wait on cores. I don't recall all the machinations that went on, but comp ended up either buy a core company or went into an exclusive contract with a supplier. Now comp had all the cores it needed, all the time.
Since most HFT and SFT cores are cast iron, they are EXACTLY THAT.....cast. The lobes, and therefore POTENTIAL LSA's are already there. We all KNOW that there are times when a 100*LSA or maybe even a 98* LSA is called for. On the other end of the spectrum, especially with the onslaught
of power adders, and specifically turbos, the LSA naturally has to get wider. A mild BB turbo engine may call for 113-114 LSA. I've seen as high as 120 LSA on a turbo alky deal, but it was well over 500 CID.
So, between, let's say, 102 and 114 LSA is where most cams will fall. To make a core that will take that spread is very expensive. And, it takes longer to grind. Unless you are somewhere in the middle. So the marketing jerks got with the engineering nerds and THEY decided for COST and PRODUCTION that 110 LSA would be the de facto standard. Comp had now birthed, blessed and baptized the living abortion of the production LSA.
It saves money because the cores can be made with less LSA split between them. It took less time to grind. They could make bank. Now the marketing pukes had to sell it, and so a media blitz raised from the pits of the marketing sewer. And all the sheep went to the slaughter. With them , they brought multiplied sheep, ripe for the killing by regurgitating this vile lie. But who cares? Money is made, they average guy is happy with "what he has" because he doesn't test, and engine builders are happy because they can stock a few generic junk **** cams and the customer will swallow them down like a 2 dolla ***** on a three piece suited John.
In 2016 and beyond, it has become almost impossible to get a core that will go tighter than 107. 106 is a push. Anything narrower than 106 and you are pretty much **** out of luck, unless you are somebody who is somebody. Engine builders no longer want to spend time trying to reeducate the customer from 3 decades of marketing stupidity. So they give the customer what he wants, even though the customer, most of whom are just casual with the hobby, have no ******* idea what they want, let alone what they need.
So engines are underachievers, and all the fools applaud and say bravo to an engine that is down on power, down on torque, has the torque curve too wide and makes RPM like a flat head ford. Yes, bravo indeed.
The facts are it's not just me bitching about guys giving up power. I PAY for power. It's what I expect. Many people for years have been trying to overcome the inertial ignorance that comp has blow right up our collective asses. It's not just me.
But just like the church of Scientology, it's hard for folks to admit that what they are doing is wrong, at least from theperspective of performance. All leave the religion of it to the rest of the Gentiles to argue out.
The LSA triangle is the single most misunderstood, misapplied and abused function of cam timing I can think of. And that's because it starts with your CYLINDER HEADS. Nothing else. If you can't make that connection, I can't help you. Every single cam event is based on YOUR cylinder heads, induction and exhaust system.
Sorry for the long, sometimes gruff rant. But it is stupid to keep hashing over numbers when ONE guy takes everything LITERAL and types a tome on the nuances of his pet theories.
With that in mind, I take BACK my comment for the OP to use the 284 MP cam. F-T-P says it will never work, so therefore, it is so.
I will go back to what I always have said. Buy a CUSTOM CAM. Don't get ate up by the LSA if it is more narrow that what the brainwashed masses claim is de facto. Rise above their ignorance. The earth is NOT flat. Never was. You have been duped by production oriented manufacturing and Madison Avenue pukes.
It's time to leave the dark ages of cam timing and get to the light.
As long as you like it... that's all the matters, making the customer happy with the end result should always come first.Lol thanks. yes things seemed to get out of control here not what I was looking for when i 1st ask about my build. some people really know their cams I was a bit lost in what they were discussing. I did learn some stuff though so all is good. in the end I think it's sweet engine. This is my 1st mopar so I'm happy regardless. It has good vacuum for my power brakes. torque curve is good to me. sounded great when running. we are always wanting more power aren't we lol but to much and things get out of control especially in a older car. I appreciate all the comments though. will be posting more once I get the car back from paint. to share my build. hopefully I don't raise a ruckus then to lol.
This doesn't change the overlap period. Are you going to try to tell everyone that overlap has no effect on idle vacuum now as well?
No we are talking about two cams with completely different overlap values to each other when you consider how much valve lift is occuring during that overlap period. I'm not saying I can't make either cam idle and be streetable, but the smaller duration cam with the wider lobe separation will idle better and be more streetable every single time. You're the one saying it won't.
I have explained EXACTLY why you can get a 255 solid cam on 105LSA to idle similarly to much smaller hydraulic cam. VALVE LASH. IT'S A THING.
anything over 108 lobe separation is no good for a passenger car? In that case maybe you should write a letter to all the major camshaft companies, as well as all vehicle manufacturers telling them they should never run a wider LSA than 108. Clearly you must know something they don't.
I would say that 99% of all aftermarket performance camshafts fall between 107 and 114 LSA because that's what suits most applications best. not because of anyone's marketing campaign or some kinda brainwashing by comp's evil henchmen. if you want something unusual, you might have to pay a bit more and go billet if you think the gains will be worth the expense.
What's there to misunderstand or abuse?? it's a graph which shows a camshaft's lift for both lobes relative to crank degrees of rotation. my picture was just an example generateed by a computer. but when ordering a custom camshaft you can get these created using an actual camshaft's lift values throughout it's full rotation, with the numerical values for reference. It's literally telling you EVERYTHING about the size and shape of your camshaft.
No need to apologize, It really doesn't bother me. However, i have no pet theories. What i do have is a modest understanding of camshaft theory.
I didn't say it will never work, i said it wouldn't make the same idle vacuum as the much smaller cam which OP is already using.
Keep fighting the good fight, brother. They may take our lives, but they can NEVER take our narrow lobe separation angles!
I did read your post. and i do get what you're trying to say. modern lobe design has a faster rate. ie more duration @ 0.050" relative to seat/advertised duration.
This is fantastic for getting lots of performance, but it doesn't change the fact that more duration @ 0.050 will still affect your idle vacuum. (everything else being equal)
Let me show you a picture i quickly made up which demonstrates this in an easy to understand visual way. The shaded area is valve overlap.
Note how Both camshafts have 60 degrees of overlap @ seat duration (each graph is 60 deg wide).
Also note the where horizontal 0.050" line intersects with the RED closing of the exhaust valve, and then again with the BLUE opening of the intake valve line. these intersections are 10 degrees apart on the first camshaft and 30 degrees apart on the second.
The shaded area is overlap. As you can see, even though both of these cams have "60 degrees" overlap according to advertised duration numbers... the second camshaft has a crapload more valve lift during that entire 60 degrees. This increases the effect of overlap and reduces idle vacuum. Any questions?
There's a very simple explanation for this.
By my calculations. if the STL5054AS-8 camshaft is 60 degrees overlap on 108 LSA with 250/254 @ 0.050" as you mentioned, that means it must be 274/278 advertised duration (i couldn't find them listed on their webpage).
So you probably think that the hughes cam is way faster ramp rate than the comp cam, right?
Hughes, 278/282 advertised duration, 250/254 @ 0.050"
Comp, 274/278 advertised duration 230/236 @ 0.050"
Not so fast.
The hughes STL5054AS-8 camshaft is a solid cam, the COMP XE274H is a hydraulic.
The standard for measuring Solid cams is 0.020" for advertised duration.
The standard for measuring Hydraulic cams is 0.006" for advertised duration.
if you get a camshaft, ANY camshaft.. and measure it's duration by both these specs. you will have more degrees at 0.006" compared to 0.020".
In the example you gave, it has little to do with how aggressive the lobe is and is almost entirely because of the difference between how each one is being measured in a different way.
The next biggest killer, and just as important is the INTAKE VALVE CLOSING point. The later you close the intake , the shittier the idle and the lower the vacuum is. This is the number ONE killer of all things guys ***** about.
So you're agreeing with me then? Or maybe you didn't understand what I'm trying to say. I have no idea why you keep using advertised duration, when I use valve events. Advertised duration is just that an ADVERTISEMENT.
As I said. Valve events determine idle quality. Not duration. Not LSA. Yes, generally with more duration idle is worse. And with tighter LSA idle is worst. BUT that's because of valve events, they determine idle. Period. Part of my point with that, is that as cam technology got better, you could have larger duration with better idle because of improved valve events.
Well the overlap on the solid was 66.
And I use intake valve closing angle at zero (ok well .006") to find overlap. Because that's how you should do it. Yes, I calculated that on the hughes cam.
So once again, my point is that valve events are what you need to look at. Not advertised duration. Because that's an ADVERTISEMENT.
STOP focusing on advertised duration. And start focusing on WHEN the valves actually open and close.
This was exactly my point. To bring up the cams I mentioned before?
Hughes STL5054AS-8 250/254 -108ºLSA - Intake valve closing angle 64.
Comp XE274H - 230/236 - 110 LSA - Intake valve closing angle 63.
Which just proves that you can have a crazy big duration, but still have mild valve events. Pay attention to valve events. They tell you what the cam is doing and when it's doing it.
so.. based on my setup if i were to change the cam which hydraulic one would you recommend. and what size of carburetor to go with it? i assume if i wanted more power from my engine later on these 2 things would be the best place to start. everything else should be fine?
There are too many people that are getting mixed up in my answers. In going to try and stop doing that. Wish I knew how to quote just part of a post and then answer it. Copy and paste is too tedious for me.
Anyway, I agree not to get all caught up in advertised numbers, but they do matter. Once the valve is off the seat about .020-.025 you start getting some flow. If you up the pressure it happens earlier. We know that at overlap, the pull on the intake port can be as high as 120 inches on a decent prepped street head. So with long slow ramps you get into issues with reversion. That's why GM in the aforementioned 30-30 Duntove junker and some other junk GM cams that I can't recall the nomenclature on, had LSA's as wide as 116. It was to help with the bi seat to seat numbers. They were **** cams.
Just so someone doesn't come along and read this **** and actually THINK that LSA is a vacuum killer, and idle killer and all that silly ****, I'll spell it out one more ******* time.
The biggest killer of low speed torque, idle and vacuum is seat to seat duration. If you have a cam with 314 degrees of seat timing, but has an at .050 of 220 that cam has SLOW ramps. It will RPM to the moon with an LSA wide enough but it will RPM slow and be a pig. This is what GM did with the JUNK 30-30 cam that some GM guys think is the best thing since Pussy. Junk is junk.
Now, take that same 220 at .050 and make the seat timing 270. You can pull the LSA in a bit, it will still idle and have vacuum. Seat to seat duration is the biggest killer there is.
The next biggest killer, and just as important is the INTAKE VALVE CLOSING point. The later you close the intake , the shittier the idle and the lower the vacuum is. This is the number ONE killer of all things guys ***** about. Yet all the heros blame LSA when it isn't LSA that is causing the issue.
Soooooooo, if you take the same cam, and change the INTAKE CENTER LINE, you change the INTAKE VALVE CLOSING point.
Crane 693511 cam
340/360 Performer intake
Edelbrock 650 Thunder AVS 1806
What about a fuel pump? Any suggestions?
