I know you didn't want to have to pull the engine, but in a way you'll be better off. Now you know you'll have a great cam and lifters. And...you have the "pleasure" of getting your hands dirty again!!
Do your heads have dual springs?Followed Lunati instructions. 2500 for 30 minutes then 3000 for 1 minute, then backing out down 500 rpm every minute.
good move , once you are doing it , do it right the first time or 2nd whatever . Hope this one works well and you burn lots of tiresTrue that. I'm also going to take the opportunity to have the rotating assembly balanced just to be sure.
Just thought maybe you didn't pull the inner spring for break in. Spitballin'No. Single with a damper. However see earlier post a about comps comment on flat tappet break-in with those springs...
Use break in oil? or an additive?No. Single with a damper. However see earlier post a about comps comment on flat tappet break-in with those springs...
is it lifters or cam that the problem ? Damn putting the engine in my car next week or so . and it is a Comp cam . So far broken in on the dyno and several pulls all is good . Next week I'll know for sure after a few 100 miles of driving will not be pleased if the cam goes bad . Don't think this is limited to Comp cams , industry wide problemGoogle Comp Cam lobe, and general quality issues.
I won't use anything Comp anymore .
What roller lifter did you decide on?I agree. Was just talking to another guy that's in the industry and he believes all the cam manufactures use the same material for their cores, they are just ground differently. I think its a quality of material issue. So I am going to try not to dwell on it, Ive always used comp. My dad just put in a roller for his 383 and so far so good. I am little nervous on the lifters, but then again, what can you do?
You can also google FiTech, Edelbrock Proflo, Holley Sniper and get a ton of hits on bad parts/systems. So I think that is just the way it is now with so much access to information.
Run a flat tappet. Problem solved. Rollers are over rated.None, at this point. Read yesterday that some small rollers don't need machine work to the block, then Seen the cam you recommended for the OP.... and then my Lil Gears Upstairs started spinning...
If the engine was a automatic when the engine was rebuilt and I assume that you had it balanced, it was balanced for the automatic, when balancing is done both the harmonic balancer and flywheel are requiredI am moving over to this forum from the 4 speed forum as I have determined that my issue is not transmission related.
I have a 70 Dart 340/4 speed. The motor was out last winter for the 4 speed install and while.it was out I installed Edelbrock aluminum heads and a lunati -10200703 cam.
I broke in the cam fine, but it has an intermittent shake at idle. It shakes so bad that shifter moves all over, but it will smooth out above 1100+ rpm. I first noticed it when I had it in jack stands to verify the clutch engagement and the driveline was rattling like crazy (intermittent).
I removed the driveline installed a slip yoke and the shake is still there.
340 .040 over
Lunati cam (number above)
Air gap
Fitech EFI
I've verified timing, played with the idle tune, double checked firing order, swapped plug wires and nothing changes.
I'm at a road block as I don't know where to go from here. I need some help.
Glad you got it fixedEverything was Neutral balanced. See above posts. It turned out to be a cam/lifter issue.
Dan he is just getting startedGlad you got it fixed
Yeah, I just got it torn out. I'm going to put it on the stand and start disassembly.
