I missed where the op said this was a magnum. He did say that he has adjustable rockers.
Pedestal rocker bolts can break with an aggressive cam, strong valve springs and the aggressive driving that goes with the previous two. That is the reason the OP has 7/16 7/16 studs. Adjustable push rods and lash caps get you back to the same situation this started with.Lash Caps?
The OP needs to go through the motions of pull the intake off to visually check lifter status regarding off base circle and plunger travel position in the lifter bodies when the valves are on the base circle. With the intake off and a piston at TDC, it is easy to verify if it or its running mate are on the base circle. Those lifters will be lower than the running mate which will be on overlap and both lifters will be raised a bit. If the lifter bodies are both low but the valves are off their seats, back the adjustment off to get clearance like a solid lifter cam and then do the one finger zero lashpoint adjust. Then tighten down the adjuster nut 1/4 to 1/2 turn to set the plunger part way down in its travel.
Working with running mates and adjusting the cylinder at TDC firing has always worked for me.
You want sensitive adjustment, try 12V or 16V Detroit Diesel timing that uses timing pins of various lengths for different injectors, or a 2300 Cummins V12 with Top Stop injectors.
I agree on degree the cam to verify. If it is off the problem could be an issue with one of the timing gears. A 340 will be a LA engine as the Magnums came much later. And I made a mistake thinking the OP has the 7/16 7/16 rocker studs. That is another poster.I get it. I said in post 2 to pull the intake and front cover off and see what the heck is going on. Clearly there’s some issues, and a bunch of really smart guys here have thrown a ton of info his way. I’d say the best thing would be the the OP to step back, regroup, read this thread, figure out if he’s got a LA motor or Magnum Motor, take a deep breath and pull the intake/ timing cover, lube / degrees the cam, pull the oil/ distributor shaft and get the thing set all back to zero...
Degreeing is not exactly a "tuneup" procedure but to verify proper machine work on the cam.and timing set. It does allow changing cam advance or retard as desired by your application to tune where maximum torque occurs. This is accomplished with offset keys or bushings and drilling the cam timing gear index pin hole oversize to fit an offset bushing. Generally for street this is not required, but verifying correct parts manufacture is.I’ve had the engine apart 3 times now verifying installation. I’ve done valve adjustment 4 times now. I’ve verified that I’m not 180 degrees off as many times now. I’ve drained antifreeze 3 times now and will be disassembling it for the 4 th time in the future. I did not find anything glaringly wrong any time I had it back apart.
This engine should at least run ok without degreeing it. It doesn’t.
I do not have it in me to continue to troubleshoot this camshaft any longer. What’s wrong with it? I don’t know but I suspect it’s ground wrong or maybe it’s a marine camshaft and ended up in a auto box. I no longer believe this is an installation issue but a manufacturing issue.
The car is up on my lift with the cover on and I’m walking away from it for a while. When I get over the disgust, I’ll take it back apart and remove this camshaft and install a different one.
Thanks much
