340 issue after camshaft change
If you can post particulars such as static compression, induction, exhaust, converter and gear, Ill be glad to help with a recommendation. ...and what engine again?
Good morning. Here’s the particulars:
68 340 4 speed. 3.55 gear. 10.5 to 1 pistons. Edelbrock air gap intake, 800 CFM carb, stock HP exhaust manifolds. 2.5 inch exhaust.
Thanks.
Don't want hijack thread but RRR would that cam work good with 323 gear ? That's the only difference with my Dart .
Since you have the adjustable rockers, I'd recommend going with a solid cam, Isky or Racer Brown. They always sound great and have the performance to back it up. Maybe Racer Brown ST-14, or call and get a custom grind.
That's a good idea. Of course he'll need different pushrods, but the difference in power will be remarkable.
I had a friend with a similar problem once with a Chevy. We finally took the cam back out and it was broken. We figured it had to have a crack in it new and went ahead and broke when we tried to bust it off.
This is how I always do it. For me it's just simpler. I copied this info. a while back as my memory sucks these days lol.
Valve adjusting
This procedure is generally called the EO/IC method, which stands for exhaust opening/intake closing. Working with the first cylinder turn the engine until the exhaust valve starts to open. That indicates that the intake valve is resting fully on the cam base circle and can be adjusted. Then turn the engine over until the intake valve is just about to close. That means the exhaust valve is ready to be adjusted. Simply repeat this process with all remaining cylinders.
The process is slightly different with hydraulic lifters. There is no gap to set; rather, the lifter needs a “preload” to ensure that the plunger is in the center of its travel. Basically, the pushrod is rotated with one hand and the rocker arm is tightened until the pushrod is snug in place or at zero lash. Then the adjuster is turned or tightened until there is enough preload. The amount the adjusting nut is turned depends on the type of adjustment mechanism as well as the lifter. Most applications will use a 7/16-20 rocker-arm stud. A full turn of the adjustment nut moves the rocker .050-inch, so a quarter turn will provide .0125-inch preload in the lifter. The adjustment on the pushrod end of the rocker arm can be calculated in a similar manner. Jesel uses a 3/8-24 screw adjuster, which equates to .041-inch movement with each full turn.
There could be an issue with your term snug. People have different interpretations of what snug means. What I do is turn the adjuster down so the pushrod still can be lifted up and down slightly (say 1/32"). At this point your index finger gently on the side of the pushrod and moved back and forth will easily turn the pushrod. Turn the adjuster down until that easy rotation stops. At this point there is zero lash but the hydraulic mechanizm is not being pushed down. Now the prescribed 1/4 to 3/4 turn on the adjuster can be made to position the lifter piston in the center of its travel.
If the snug interpretation is the pushrod can not be rotated using a finger and thumb, the lifter is probably collapsed to the bottom. Then the preload 1/4 to 3/4 turn is opening the valve.
Personally I prefer the 1/4 turn as it moves the piston down slightly allowing the lifter to function as designed, but not much for pumpup on high revs. If you do get to the pumpup state, power will go flat.
I’ve had the engine apart 3 times now verifying installation. I’ve done valve adjustment 4 times now. I’ve verified that I’m not 180 degrees off as many times now. I’ve drained antifreeze 3 times now and will be disassembling it for the 4 th time in the future. I did not find anything glaringly wrong any time I had it back apart.
This engine should at least run ok without degreeing it. It doesn’t.
I do not have it in me to continue to troubleshoot this camshaft any longer. What’s wrong with it? I don’t know but I suspect it’s ground wrong or maybe it’s a marine camshaft and ended up in a auto box. I no longer believe this is an installation issue but a manufacturing issue.
The car is up on my lift with the cover on and I’m walking away from it for a while. When I get over the disgust, I’ll take it back apart and remove this camshaft and install a different one.
Thanks much
Cam pt# or grind# should be etched or stamped on the cam somewhere. Does that matchwhat you paid for. A call to the manufacturer would be inorder. They do not want a bad reputation getting spread, so should offer some suggestions or replace the cam.
Small block and 351 Fords can have the confusing firing order issue, but that is not the case here.
Always works for me. One finger to get zero lash and the little spring in the lifter will provide enough drag to stop the pushrod from turning.
Hope I'm not over stepping here. I am not a engine rebuilder, but have installed cams before. I do not want to repeat what was already stated. I do hope cam lube was applied to the lobs while install, do to all the dry runs, before proper cam break-in. Never had this issue, but I would think a Dial gauge reading at the rocker arms would let you know if the cam was in defect, before taking down the install again. Just saying!!!
Hey
Im a long time reader but usually not a participant on these threads.
Because they they seem to be hijacked to some different topic. AND
What I hate, is, a lot of times the topic starter never chimes up with what the solution is!!!
I started at the opening question and jumped to page 4.
Hydralic lifter- you have the intake installed and can’t see the lifter. And you cannot see how much you are compressing when you adjust. It could bleed down while adjusting. Cant go by feel.
Hell, adjust loose and let em rattle till you get her started and running.
Myself, I like to run the oil pump primer rod on a drill, to make sure the lifters are pumped to the top before playing with hyd. Lash adjustments.
my 2 cents may not be worth the zinc they are made out of.
I welcome any thoughts and comments.
At this point, it’s very probable the grind is not right.
IMHO, you need to get to the bottom of the problem. To do that requires degreeing the cam. You do not need to remove the head to find true TDC. A small screw driver or bit of coat hanger or welding rod will let you feel the piston come to the top and start to drop. Back up a few degrees and install the degree wheel. A piston stop can be made by grinding or cutting the crimp that holds the porceline in and push it out. Weld a nut on to use the largest diameter redi rod that fits through the plug body. Grind one end of the redi rod round and then cut it off about 3" to 4" long. Loctite a nut on the cut end to turn.
Now you can install the body in the #1 plug hole and thread the piston stop rod in until it just touchs the piston crown. Back it out one turn and roate the engine about 30° to 40° ATDC. Turn the piston stop down about 3 turns. Now you can back up the rotation until slight resistance is felt. Note the degree indicated. Now rotate in the normal direction until you feel the slight resistance again and note the degree reading. Now pull the stop out and rotate to half way between the two noted degrees and move the zero mark to line up. Just to be certain at this point I would go to 40° ATDC again and install the piston stop. Now check your ATDC and BTDC degrees. They should be identical. Now you can check timing per the cam card supplied with the cam.
There could be an error with the cam grind with regard to the relation to the keyway or a key slot in a timing gear could be off. With #1piston at true TDC the crank timing gear dot should be straight up and the cam gear dotright opposite. You know this. #1 or #6 should have both lifters raised a slight bit with the other on the base circle compression. If not, one part is likely machined wrong.
At this point you likely will remove the timing set to get at the cam. Try it on another engine. Maybe someone close has an engine apart or a spare. This will verify the timing set which is way less expensive than a cam. If it is the problem and you purchase another cam and heave the one you just took out 10' into the scape heap, you could still have the problem.
Realising that most companies unfortunately have stuff manufactured in the land of recycled Yak turds means either the company or the customer needs to have a QA/QC program to ensure quality.
My definition of snug is, not torqued with a torque wrench, but tight enough that it will NOT back off. That's for "whatever" size fastener.
You learn what snug means by experience. That means that ultimately you learned “feel” by: stripping **** until you learned to ease up on being ham fisted. Feel the bolt/nut. Slow and easy up to snug and no more. Grandpa taught me that one.
