I used a reusable gasket.....Hard plastic of some sort....Glad you got it to stop. Was the pan gasket re useable? I've known about off setting of the rear main seal for a long time
OMG. A brand new rebuild that was NOT a rattle can rebuild. Leaking!!!Glad you got it to stop. Was the pan gasket re useable? I've known about off setting of the rear main seal for a long time
You have a brand name or a part number?I used a reusable gasket.....Hard plastic of some sort....
Well Turk, It's a seal not a bearing. I've put together 11 engines since 2009. Mine and some friends. Always used a Superfomance "pink" rear seal and always clocked them 3/8 offset.Dan, I’m one of those guys who’d tell you that not all of us clock the seal offset like that.
You need to learn to fit the rear seal rather than offset it.
Think of that seal like a bearing and then tell me if you’d ever offset a main bearing like that and why you’d do it.
Not one has ever leaked a drop. Way back then, Rick @ Superformance told me that's the way ya do it. So I considered his advice gospel. I was brand new to Mopar.
ALL OF THIS is correct!It’s not a bearing but it has crush LIKE a bearing.
If you fit the seal correctly you don’t offset it.
That came from a 1995 Felpro sealing seminar I had to go to.
If you are offsetting a two piece seal you need to find out why it’s leaking if you don’t. And it’s not that the seal is leaking at the split.
It’s because the seal is too proud and it gets over crushed and the seal deforms.
Offsetting the seal doesn’t fix that, but it’s a hack that half assed works.
The correct installation is fitting the seal.
I love Superformance gaskets but he’s wrong on that.
Show us the correct way to fit the seal.It’s not a bearing but it has crush LIKE a bearing.
Have you done a CC pressure test yet?Has anyone ever run into this before?? I cant figure out what could have caused that substantial of a leak.
I've never in my life offset the seal and knock on wood have never had a main seal leak.Dan, I’m one of those guys who’d tell you that not all of us clock the seal offset like that.
If offsetting was the proper way, I'd be in every factory service manual ever printed. It's not.Yeah, the way you fixed it is best.
Offsetting the seal effectively keeps the seal from getting the proper crush.
If you have a seal leak, and you offset it and it seals you reduced the crush. In other words, the seal is getting too much loading on its ends because those ends are too proud of the cap and block.
Correctly fitting the seal (both halves) for proper crush and the seal won’t need to be offset to not leak.
I tried to get into a conversation with DTM but he is convinced that offsetting the seal is the proper fix so I didn’t waste my time trying to show him that just because people are doing something doesn’t make it right.
Well. Call me wrong. But I'm gonna continue my wrongness as long as a Superformace seal is involved.
I can tolerate a lot, but NEVER a drop or drip of anything. Not my cars, my truck, tractors and especially my body!
My intention was not to start a uproar over the installation of a seal, I just was saying what I did in the past and it worked I'm not saying that it's the right way or the wrong way to install the seal. I don't remember how many I have offset or how many I put in the normal way. I will say this for sure, it's important that all surfaces be cleaned and inspect the seal for defects.
great NOW you tell me!Superstition is a bad way to build engines.
No, I've learned the better way to do things.See post 22 Dan.
This is why it’s just not worth it to tell people there is right way to do **** because they’ve done it wrong forever and it works so they keep doing it despite overwhelming evidence.
There is a correct way to fit a two piece seal. Offsetting isn’t it.
But carry on. It works right?
Thanks, I appreciate thisDan, if you learn only one thing from me, I hope it’s to not take MY word for anything more than a bullshitter on the internet.
Take my words for NOTHING.
What I want you to learn is question everything, assume nothing and VERIFY EVERYTHING.
Then you will KNOW you are doing the best thing at that time.
Things change and evolve, so what we do today may not be the preferred way in 10 years. Or 5. Or even 2.
So verify what anyone tells you. I do that by calling the engineers who do this stuff when I have questions.
Go to the website I posted and watch all the free webinars they do. You can’t pay for an education like that.
Another one is epartrade.com. They are well over 150 webinars now and the topics vary widely.
Go get the Taylor books, the two volume set read it. I can’t remember the exact name of the books now but it’s Charles Fayette Taylor. Look it up.
The upshot is just because I say something is the right way to do it, don’t just accept that as gospel.
Get on the phone and verify that stuff. From multiple sources.
Then you can go out to the shop knowing you’ve done your best to learn the best to be the best you can be.
Don’t take my word for anything. Always verify.
Thats how I do it and not a drop of oil leaks outon a SBM I just put a tiny dot of the right stuff on the ends of the seal and a thin smear where the cap meets the block - no leaks so far.
I offset the rear main seal if its one of the old rope seals, but I am a hobbyist not an engine builder (so probably doing it wrong).
On a SBM I just put a tiny dot of the right stuff on the ends of the seal and a thin smear where the cap meets the block - no leaks so far.
