the chamber is likely smaller than 4.100. besides that chamber needs workYou have to be careful opening the chamber up bigger than the bore.
You can create more issues doing that.
4.180 gasket, bore is 4.100…
Tire will be 27 or 28” tall, copper cobra 275 or 295.
I was planning to use mild timing curve in msd distributor, also limit max timing and use cold plugs.
This is 100+ actually. Works perfect in 12.5:1 big blocks with not big 270/[email protected] cam.100 RON is about 96 in the US....still good stuff
About 3300 without overdrive and 2500 with overdrive.So at 70 MPH what does that give you for a cruise RPM?
I have 3200 converter for this thing.
Plan was to make it a good driver…Unless the road is very flat, at 2500 in OD you’ll have a bugger of a time keeping it out of detonation. Any little change in load will get it into tip in detonation.
You’ll have to be very careful.
Is that head gasket really going to do much? It’s like 11.8:1 with quench vs 11.5:1 without quench…At this point in time I'd cleanup the chamber and use a 0.050 head gasket and send it.
there's still quench at 0.050, it's the limit. Don't you think there's something to be gained by working the chamber?Is that head gasket really going to do much? It’s like 11.8:1 with quench vs 11.5:1 without quench…
Piston is not at zero deck.there's still quench at 0.050, it's the limit. Don't you think there's something to be gained by working the chamber?
There is no option to run 4.10 in this, it’s already crazy over invested project ;-)Then you missed on the compression ratio. You have to make compromises somewhere.
I‘s work on getting the compression down to 11:1 if you want to run that gearing.
What does a 4.10 gear look like for cruise RPM?
Any pointers? Chamber photos?70 is possible with that head. 5cc’s out of that head is do-able.
The shape is the important part now.
I like the direction this is going in. Everything is pointing towards a good direction. Ratbastard is on target. Been there done this myself. No 2 cents to add in.
Sorry, no can do. All are on running engines and I don’t have photos.Any pointers? Chamber photos?
Rotating assembly is already balanced as is. The only thing I can touch is the heads at this point and play with gasket thickness.Change pistons or machine a dish in them.
You need to find about 12-14cc's, not easy to do.
Heads were bought bare, they have new valves, guides, springs seals and locks. Springs to match the small hydraulic roller cam which will be used with solid roller lifters.Miszny:
[1] Leave the heads alone. Run it like it is. If you look at other aftermarket parallel valve heads [ Chebby, BBM, Pontiac, Ferd Windsor, etc ], they all vary slightly in the combustion chamber design....but all run well.
[2] I have had 8.5:1 engines detonate on 98 fuel, but my 9.9:1 engine doesn't detonate on 91 fuel. You have to run it to see......
[3] I agree with installing the cam straight up on 108 ICL because of the cam duration & 3.9 gearing.
[4] Did the E heads come with beehive springs?
