1wild&crazyguy
Banned
Ah old school **** style photography... a lost art.
Fuzzy, grainy and can't make out the details. You tease.
Yeah...the 1st one is hard to look at.. & there's a couple more to burn yer eyes with too
what valve angles would you suggest for for a .500 lift cam after lash? at this point would you gain much with a 2.02 valve and bigger bowl over the 1.88? i wonder about the bigger valve shrouding and and slowing air speeds. not an expert by no means just wondering thanks.
I'm porting the same head as Justin, and was determined to cut in a 2.02 valve.
The 2.02 changes the hole characteristic of the port. above 250-260 cfm the air flow quality go to hell in a hand basket!!!
Been porting on these head for 2 years now................still not happy with them.
If your going bigger, go with a 1.94 Valve, it give you room to port with out finding water and creating turbulence!!!!!
O and the only thing a flow bench does for you..........IS KEEP YOU UP ALL NIGHT, TRYING TO MAKE IT WORK FOR YOU
I imagine the ssr is the short=side radius, ill assume that it is the short side going into the bowl from the floor of the port. sometimes know as the waterfall. I used to do some porting back in the day for a guy down in fl. Some tricks; widen the waterfall and have it very consistantly smoothed radius. Also, do not concentrate on the pushrod side of the valve guide boss too much. the other side produces swirl and turbulence and if you make each side, similar flowed troughs, they somewhat cancel each other out. widen the pushrod pinch as much as possible or actually install copper tubes in the guide holes and port the pinch 'til they expose the copper, stop there. (expoxie tubes in place). raise port opening as much as practible. shorten guide boss a bunch but leave the "tail" intact. 11/32 stem chevy valves, at .100 over length at exactly 2.00 diameter (1.94 work good in a 318 bore). pocket of bowl opening should be at 1.80- max diameter min. 1.75
with 2" valve. 3 angle valve jos with 45 degree seats. 5 angle if you can afford it.
later 360 heads have one "bad port" that you cannot make to match the others due to a bolt location creating a different shape to accomadate it. cant remember the earlier's X or J 'd design on this. as a rule of thumb with the small block, the bigger you go the better it will flow (within reason and keeping a few exceptions in mind).
you can get rid of the valve cover bolt boss that protrudes onto the port opening as long as you fill it up after (epoxy etc) and remember to use short bolts in that location.
I would wait until the valve job is done because the back cut on the stock valve, or the nailhead valve, will change the flow numbers and the character of that flow. I always have the valve job done first because it corrects the angles accross which the air has to turn, locates the valve properly in terms of proximity to the chamber wall and in relation to the valve centerline, and takes care of any leakage and inflating of numbers that can happen with worn guides as the valve is run through the lift motion.
Looks good Justin. Those Boat Ancor Heads I have are ready whenever you are so you can experiment.
Not to change up the topic but....has anybody tried those new cheap (relative term)
flow benches? You know the ones that interface with your laptop (or whtever) and use the shop-vac (must be 5 HP shopvac minimum). I was watching the vid and it seems like a pretty sweet deal for the home user, supposedly it's very accurate.
That's what Justin has and it was REALLY close to a superflow bench for rated numbers on the same day. We used a HD shop vac at my house, worked well.
It was neat to see the flow diff from here at the beach @564ft elevation to sea level or below with dry desert/thin air.
the air will show diff numbers on the same bench, like how at home I get 277 cfm out of a port that in Indio only showed only 273-274cfm on the same bench, then reaffirmed the numbers on brians.
I honestly was sweating it cause if the superflow didnt show the same...it would seemingly make me out a liar, which Im not...and then I would have go and correct all the posted info...plus I would have wasted $1300.
Justin, I'd bet those number you got at the (Valve mod, SSR, Chamber) would be real close to the one my heads got with a good VJ. Think mine went static at .450, right, then held steady at that rate through .550
