Bulldozer
free ice cream sandwiches
i have been fighting valve train noise for some time and i decided to get some input. i have put together a number of small and big blocks, but i have never ran into this before. engine is a 77 360. came out of 33,000 mile cordoba. this engine is super clean and ran great when i bought it. it had a slight ticking, but great oil pressure, that i contributed to weak lifters/exhaust leak. before i put this in my charger, i did the following:
pushrods were all checked and are at spec
new oil pump
new 284/480 cam kit with new lifters:
Hydraulic flat tappetBasic Operating RPM Range2,500-6,000
Intake Duration at 050 inch Lift228
Exhaust Duration at 050 inch Lift228
Advertised Intake Duration284
Advertised Exhaust Duration284.
Intake Valve Lift with Factory Rocker Arm Ratio0.480 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio0.480 in.
Valve Lift with Factory Rocker Arm Ratio0.480 int./0.480 exh
although the summit cam card recommends new springs, i talked to several techs and they ALL agree that my factory valve springs are more than adequate for this cam, and with it being such a low mileage engine, i did not change the springs.
new stamped factory rockers and shafts
i pre-pumped the lifters and primed the pump before installing
new double roller chain and sprockets
i then bolted the shafts down and while triple checked everything by spinning it around by hand , i noticed that when the rockers/valves are in between opening and closing the given pushrods were loose, so much so, that i could get .060 feeler gauge in between the valve tip and the rocker . the valve train should be tight all across the board no matter what position the rockers and valves are at. i was stumped. so i went and ordered a set of .060 valve lash caps and put them on and that tightened everything up. but why in the world would i need a .060 lash cap in the first place? . got it in, fired it up, broke in the cam. and no noise what-so-ever, purred like a kitten with a slight lump. i love this cam, fairly mild, with a great idle.
this engine has excellent oil pressure and runs great. i have about 30 hours of run time on it and it is a very healthy engine.
there is no metal in the oil and the oil pressure is 70 at start up and after about an hour of running it has 40 at idle.
it has slowing started to develop a tick. and the other day it was pretty loud and it is only over the #6 and #8 pistons. it almost sounds like a solid lifter motor with the valve lash out of wack. these lifters are brand new and i would hate to think a few already collapsed plus the thought of tearing into it is just disappointing.
i have played with the timing which is at about 12in/32total but has no effect on the valve train noise. im trying to be as clear as i can . any thoughts on this would be great. as usual, thanks a million guys
new oil pump
