just trying to help here. egag has a dual pattern airgap styly knock off from kmj performance item number 392947209070 for 199.00 w/free shipping. just trying thelp if m1 is too much.
Is that Promaxx iron head a China cast you think? I know Hughes offers an iron head also, haven't looked up lately.For cylinder heads, there are available for you in;
Iron, stock replacement style.
Once such example below, do shop around though.
CHRYSLER 5.2/5.9 MAGNUM New Full - PROMAXX Performance Products
Edelbrock aluminum for the first step up in performance.
Edelbrock Performer RPM Chrysler Magnum Cylinder Heads 61775
Trick Flow heads that will then use a LA intake but yet you will still be able to oil through the pushrods with the correct Harland Sharp rocker arms.
Parts and Accessories - cylinder-heads part-type - trick-flow-powerport-190-cylinder-heads-for-small-block-mopar product-line
You can also use Comp Cams Pro Magnum rocker arms to use oil through pushrods on stock or Edelbrock heads since they allow pushrod oiling. The last two options allow the use of cheaper & a wider verity of LA intake manifolds.
The iron head? I’m sorry, I really don’t know. Call ProMaxx up. They were really good to talk to on the phone. FWIW, I’d buy from them again.Is that Promaxx iron head a China cast you think? I know Hughes offers an iron head also, haven't looked up lately.
Have you talked to PIE about these heads? That is the same description they used when they were preparing the good Engine Quest heads that were cast in New Zealand. Do not trust any advertisements right now about cast iron Magnum heads. Most places still have the same info, but they are using the stock style replacement castings, since nothing else is currently available.After a lot of thought, investigation and working with our engine builder. I believe these are the heads we are going to go with. Of course you can go with more expensive heads that are made out of aluminum but for my daughter's budget and based on these performance numbers it seems like a good deal.
Mopar EQ Cylinder Heads
Well visually the heads seem to be okay but I haven't had them apart. But as things do, this engine build has turned into a different direction. The stock heads are not going to work for where we're headed. In talking with my machinist who I've worked with before (quite a few years ago he built a 360 LA motor for my wife's 'Cuda, that thing was freaking hot!).Have you talked to PIE about these heads? That is the same description they used when they were preparing the good Engine Quest heads that were cast in New Zealand. Do not trust any advertisements right now about cast iron Magnum heads. Most places still have the same info, but they are using the stock style replacement castings, since nothing else is currently available.
Is there a problem with the old heads on your engine? If not, just run what you have and save your budget a bunch of money.
67Dart GTO...I mean GTGO, I have the same intake and planning the same set up. Just pulled fitting out the box, you think it might help a little to trim the fitting down shorter, cut the first 2 barb notches off of the total five, leaving 3 ? I don't think it would hurt. Yours appears fine. Motor detail is excellent, looks very good. What heads and cam specs you running?I'm running the magnum eddy air gap with LA cover, water pump and pully's with power steering. I used the stock LA hose in question and it was a ***** to get on with the long air gap fitting that came with the intake but you can muscle it on with no kinks and get a smooth profile if your patient with it. This is the second hose I installed as I did a cam swap and replaced the first hose which I had trimmed to fit. I wasn't as happy with the first/trimmed hose as I am with this one. I was definitely more patient the second time.
The M1 single plane operating range is the “sweet spot” but it works fine on the street.
Why is it all torn down now; major changes or just little stuff?
RammerJammer75 shows how well the bypass hose will work in his second picture. Nice picture.
Just for reference, I will attach a picture of an M1 dual plane for Magnum heads and with Magnum bypass hose and thermostat.
Yup. Mine is Magnum intake bolt pattern, Magnum thermostat location and size, and Magnum bypass hose.
Not quite yet. You know how it is, it's a ton of work. All kinds of little problems to solve. The biggest issue at the moment is the right side of the Doug's s ceramic coated headers wants the same space as the torsion bar. They sent me a new one but I haven't tried it yet. We've also decided that since the clearance is so dang tight with the headers, we're going to have to run solid mounts. The MSD distributor wants the same space as the variable speed wiper so I've had to convert that to a two-speed wiper and it just barely fits.Hey @Six Barrel Bill did you get the daughter's car going?
Thanks man! There are definitely days I just want to give up cuz I'm so frustrated, but we're so far along I can't give up. Just got to get this thing done!Whoa! Looking good there buddy! Looking good.
LOL, yeah she decided she didn't want a carburetor. That's the way I would have done it.I see EFI now, too. What system are you running?
Yeah that was a little disappointing but I've come to expect it with this engine and especially this car. Nothing just bolts up.Often is such the case. It’s not the intake by itself but the cumulative machining here there and everywhere. I had to take the same amount off of the wife’s intake and I did mine .070. This mainly comes from milling the deck. Also the cylinder heads. Head gasket thickness also has a play. These three things will stack up to make part fitment an issue every time. Standard expected fodder for engine building.
