Huh?
It would be sooo interesting to hear your opinions after your test run!
With that narrow LSA it should make a lot of power from the bottom. I'm sure you will get tears in your eyes if you're behind LOL
The amount of Overlap is due The LSA. How can...I feel overlap is an very over looked cam spec, like to see what the same overlap with different lsa would do to the powerband
