Joey N
Active Member
Where do I find the build?Take a look at Rustyratrods 400 build, you can follow it for your 383 build.
Personally I like the 509 cam. I used one in one of my 440s. I also used the 509 small block cam in a 340.I believe it was to be comp cams nostalgia cam kit it was I think .509 lift
I have a A833 OD that ill have to take to a shop i believe its from 77 Has a plat on it that i believe was put in an A body at some point maybe someone here could tell me. Ill try and find a pic of it and post it below within the next hour currently in Class!Contact @MOPAROFFICIAL for head work or help, he's in your area.
You already have close chambered heads use them. About the only thing they need is mild port job and a bigger exhaust valve. In the picture it looks like they have the 1.5 or is it 1.60 exhaust valve but I could be wrong.
It looks like you could clean up that bore with a hone job, put a fresh set of rings and bearings in it and that short block would be good to go.
Throw in about a 480 lift purple shaft for a cam. You already have the intake. Stick a 750 or 780 Holley vacuum secondary carburetor on it. Or a 4779 holley 750 but your mileage will drop.
Stick it down in that a body with a set of b-body headers for a 383 and drive or cruise across America with it after you make sure you have a good transmission.
FYI you can use B-body headers in an A body with a 383 but you cannot use them with a 440. The reason being the 440 is an RB block which puts the heads farther out toward the fenders. Which makes the tubes hit things.
That is one heck of a cylinder pressure robbing grind.I believe it was to be comp cams nostalgia cam kit it was I think .509 lift
Does your school have an Automotive class?I am certainly no rich kid I bought the engine for $700 since then been working every few days after school in a grocery store for this build it’s honestly one of the only things I look forwards to every day is thinking about getting it in the car lol. I’ll get better pictures of the cylinders and the piston tops I’ll clean off so we can see the stamping clearly
No sadly I was thinking of transferring but I’m already half way into my junior yearDoes your school have an Automotive class?
Take a couple tires off and see.Can anyone tell me if 15x8 4.25 backspacing rears will fit on my 73 duster aswell at 15x6 3.25 backspacing on the front? Also it has disk brakes on the front drums on rear
Okay I’m not thattt dumb man I haven’t bought them the guy said I could steal a few pics and ask on forumsTake a couple tires off and see.
Oh I know you didn’t say that I’m just joking but thanks I should by then anyways since they’re made in America not Chinese stuffDidn't say your were dumb. anyway those wheels should fit
Is there a plan?The heads need guides, exh seats were going away they were so bad.
Springs were in at 1.883 130-135 seat and 250ish @.500
RRR's Guide to Hot rod bliss for big blocks.Man, yall are just makin this SO dang hard when it does't have to be. Just build up a stone stock blueprinted 383HP engine and call it a day. Blueprinted = what the factory did NOT do. That includes decking the block to the factory spec and making it squared with the crank centerline. Have the crank ground and indexed. That means every crank throw is exactly the same. Get the heads milled so the chambers are all the same size. Use a set of the Speed Pro HP pistons so they come up in the bore good and tall at TDC. Use the STOCK spec Road Runner cam. Get a distributor with a good, loose advance curve. Bolt on an Edelbrock RPM intake, Quick Fuel 750 mechanical secondary (double pumper) and a set of headers. The stock factory torque rating on the 383HP is 425 LB FT. That's FOUR HUNDRED TWENTY FIVE POUND FEET. With the above machining techniques and added bolt ons with the good ignition curve, you will be all over 500 LB FT from a basically stock 383, with GREAT street manners and vacuum out the BUTT to run power brakes. WHY do it any other way?
Yup, once again run over and buried. lolRRR's Guide to Hot rod bliss for big blocks.
What I meant by seats going away was they were leaking some due to guide play.How much less to recondition them compared to a set of $1400(plus shipping and a tax) Stealths?
At my shop the price would likely be pretty close…….depending on exactly how bad the oe heads are.
Nothing fancy, a set of $168 Falcon valves with locks, have guides done.. maybe option for a hard seat and do a better valve job, working exhaust ports a little bit for that bigger valve. If anyone don't know already... he has eight to one sealed power/FM Pistons and all of the aftermarket heads are a lot larger in chamber size. I think when he builds something with a good 10 to 1 piston he should buy a set of aluminum heads.Is there a plan?
Thanks for helping him out.What I meant by seats going away was they were leaking some due to guide play.
Guides replaced and 168 dollar a set 2.08/1.74 valves with a lil blend in. Considerable amount less. I haven't cc'd his chambers yet, I will and see where it's at. Obviously I'm considering the compression in this, he really needs some and or to keep it, being this low. Money is the other factor, he's in college.
