mygasser
Yes, either the valve tip isn't square or the roller rocker is sitting cocked for some reason.
Ya, I haven't checked the other head yet. I usually check things 2 or 3 times, I'm just missing something on this oneI`d b worried about that too ! Sumpin aint lined up right !
Thanks for the replay. I just used a straight edge on the valves, 2 different straight edges. Think I need better glasses tho lol. I'm going to check the other side and see what happens, thank youYes, either the valve tip isn't square or the roller rocker is sitting cocked for some reason.
Not to sure what taper height is but I did measure 1 end then the other end.Left end is .597 from valve cover base and other end is .589 . Is there a better way to measure this ?Could it be the rocker stands are not level, and taper in height ??
I've used to different straight edges and wish my eyes was better. I took everything off the rocker shafts and tried with 3 different rockers ( sliding back and forth a Little) and seen most of them fever 1 side. I checked the rocker stands and did come up with end to end difference. Think famous Bob has seen this beforeWith the rockers removed lay the edge of a steel ruler (or similar) along the tops of the valve stems. Even if they're slightly different heights you'll be able to see if the tips are parallel to the straight edge. The same applies if you put the ruler in/along the bottom of rocker shaft recess in the head. If both checks look 'level' then the rocker arm pivot may be bored pissed.
Neil.
WHAT DOES ANYBODY THINK OF INDY HEADS FOR BIG BLOCK MOPARS ?? I HAVE 3 400 INCH ENGINES AND 2 440 ENGINES . I LIKE THE 400 THE BEST BUT HAVE NEVER BUILD A FULL ALL OUT HORSEPOWER ENGINE SO LOOKING FOR YOU GUYS TO STEER ME IN THE RIGHT DIRECTION . I ALSO HAVE A 1967 383 ENGINE 318 AND MANY MORE ENGINES FROM 1984 TO 1988 2.3 TURBO FORDS TURBO TBIRDS TO 1989 CHEVEY IROCS 1989 PONTIAC WS6 FIREBIRD ENGINES AND CARS HAD THEM FOR YEARS IN MY GARAGE AS WELL WANT TO BUILD A 500 INCH 400 ENGINE AND ON HORSPOWER THE SKY IS THE LIMIT JUST WANT TO KNOW YOUR GUYS EXPERIENCE WITH PARTS AND HORSE POWER RESULTS . ALSO HAVE A 3300 LBS 1977 DODGE ASPEN RT SUPER PACK CAR THAT I BOUGHT WHEN I WAS 17TEEN YRS OLD IN 1983 AND WANT TO RESTORE IT BECAUSE OF ALL THE MEMORIES AND BECAUSE THEY DID NOT MAKE MANY OF THEM . MY RT IS A ORIGINAL 4 SPEED STICK CAR BLACK SUN PAINT WITH BLACK INTERIOR . THE BLACK PAINT HAS ALITTLE METAL SPECKS IN IT WITH THE RED AND ORAMGE STRIPSHi guys it’s been a long time since I’ve updated my rookie build. Motor is up and running and as of a few weeks ago and quite happy with it. I’ve also changed vehicles again ( #3 ) and drag only. I sold off the Holley sniper setup and just went to old school msd and a thumper 1050 domi on 100 fuel. Since there is no tracks open I’ve just done some middle of nowhere testing View attachment 1715495518View attachment 1715495519
I HAVE A DISABILITY AND I DONT HAVE FULL USE OF MY HANDS AND TRYING TO CHANGE THE SHIFT KEY IS VERY DIFFICUALT JUST SO YOU KNOW . AND YOU ARE THE 50TH PRESON TO SAY THIS TO ME . SO REALLY WHATS THE BIG DEAL ABOUT UPPER CASE AND LOWER CASE ANY WAY SO JUST FOR YOU AND OTHER PEOPLE LIKE YOU I GUESS I WILL HAVE TO PUT THIS POST ON MY INFO PAGE HAVE A NICE DAYDude... are you taking the piss? and turn off the Caps.
How about he tries a little harder, not much, just a little.How about giving this bloke a break???
How about you stop the pandering to make yourself feel better. Stop treating the guy like he's a hopeless victim. People with disability's just want to be treated like everyone else, not hopeless basket cases. I'm just treating him like a regular person.How about we give him the benefit of the doubt? He says he has a disability & neither you nor I know how bad it is or how much it affects his hand movement.
I'm simply being practical and using some logic. Very strange that those two keys are unusable..Well aren't you clever, pencil in mouth & typing!! Clap everyone. I hope the pencil was not removed from another bodily orifice, it sure sounds like it....
'You can't see any reason....'.
That's the problem. You don't know this fellow & neither do I. He could have a birth defect, had an accident or be disabled from serving his country in a war zone, illness, who knows.
You jumped on this fellow as judge & jury; he said in post #87 he had typing difficulties.
I do not pander to anyone, certainly not upstarts like you.
You are a piece of work Bakerlite, or whatever your real name is.
Nope, that's not what I'm saying.So with your warped logic, he cannot that be that disabled....because it was only a car accident.
