Not to burst your bubble, but cosmetic powder coating is not really suitable for exhaust applications. What you need is a high temp ceramic coating; without it, you'll be pulling the exhaust back off in less than a year.
deleted. My apologies to Brian.In normal traffic, it runs right at 200. When it hit the higher temps I was running 70 mph running down the highway at 3000 rpm for about twenty minutes. I don't plan on doing that too often.
...So I'm backing into a spot that my buddy saved for me and when I put the car into Park I could tell something wasn't right with the shifter. I was still in reverse. So I shut the engine off and put the parking brake on and got out like nothing was wrong (remember, people are still watching and staring). Turns out that the cable end had come loose from the shift lever at the transmission, right on top of my scorching hot header. At least it stayed together long enough for me to back into a spot.
I had been meaning to adjust the shifter because the 2-3 shift required that you hit the shifter twice for some reason? I read the instructions again and they said that the cable needs be installed with the trans and shifter in first gear. I'm pretty sure everything was in Park when we hooked it up. I'm hoping that's the problem. Of course, the hardware that holds the cable to the trans lever is long gone, probably somewhere on the road to the show. I'll have to try and find a more permanent way to connect the cable.
I haven't updated this thread lately because I haven't been doing much to the car besides driving it! Tom came over a couple of weeks ago and we put on the 3" mandrel bent exhaust along with his hi flow mufflers. They sound real nice but we've got to work on getting tail pipes on it to get the exhaust out the back. I bought some 3" tailpipes from Heartthrob Exhaust that are meant for a Camaro/Nova (I know, blasphemy!!!) that Tom thinks we can cut up and make work for my application. He came over the other night and that is going to be a winter project. It will involve moving some brake lines and maybe even rotating the calipers out of the way. We shall see. Here's a pic of the exhaust installed.
I've been playing around with the timing and think that I've got it finally dialed in. I was getting a little concerned because we originally set it up at 20 degrees intial 35 total and I've been driving it that way. I bumped it up a degree and it ran better, so I bumped it up another. Currently running 22/37 degrees and it seems to like it real well.
I'm taking the car to a chassis dyno this afternoon and they are going to dial in my jetting and metering rods using an air/fuel gauge. It's a friend of a friend thing and he's doing it in his shop after hours at a discounted rate. I'll try to post up a video and some numbers tonight if I'm not too busy out burning tires!
We are going to play around with the timing a little today on the dyno. I wanted to have it set as close as possible so that we didn't spend a whole lot of time on the ignition. I'm mainly going to get the carb dialed in.
