j par
Well-hung Member
I have brass or had brass shift forks in there and at the time I was doing a lot of drag racing so I felt it a good upgrade to put steel shift forks in...
It could be a while so I'm sure we will be hanging out before then man!.Don't forget to p.m. me when you take it down to the track! I want to be there for sure... I'm positive with your accompanying trick flow heads LOL you'll have the last laugh...
Sorry your thread got sorta hijacked Idaho
but you started it mentioning Thumper in the first thread
IMHO you are much better off with your cam than you would be with a thumper cloan
keep us posted with results
all the best
does it not have 4 degrees ground in alredy??
if you are near max recommended compression range I would bit advance it
I'm sure this is the first question I asked on page one but is it a solid lifter Cam and hydraulic lifter cam a roller cam?Now that I'm looking at it I'm wondering if I got the wrong cam.
The specs say 1341 when I ordered a 1357. This is a smaller cam.
My mistake for asking that question without the info.
It's going into a 69 Dart resto mod, maybe 3200 lb? Just a tire burning street cruiser, maybe a rare 1/4 mile.
360 Magnum with stroker kit
9.8 static CR
RHS heads by IMM
Air gap intake
750 Holley carb
Dougs 1 5/8 headers
A833 OD (has to be a stick)
4.10 diff
28" rear tire (285/40/18 IIRC)
HDK front susp.
Well, fine, but that makes no sense to me. I absolutely love certain engine sounds. The starting cough cough sputter and rough idle of a big radial like the DC3s I used to work on is almost akin to making love. It just tickles a special part of the brain. Anyone who has been to an airshow and heard either a big radial or V12 in a warbird cruise by at close range...
I've been around the modern fighter jets a lot. Awesome in their own way. But the sound of the piston powered warbird is on another level.
Yep it looks like he's going to have to take a touch more off the base circle..Yes it's a hydraulic roller.
The machine shop helped with setting it up for a 9.8 SCR. I did the head cc at 62 cc, and he verified. I don't recall the other details.
Thanks for that clarification wyrmrider, I wasn't sure how to determine how it was ground.
I'll be in touch with Ken. Must have been a crazy day at the shop. Maybe Covid 19 related
I suppose I could change to anything now.
Yes, I have an adjustable pushrod to be used for that purpose.I assumed you were waiting for the cam for the pushrods to be ordered..
A quality double roller with several grooves for different timing on the bottom crank sprocket will doYes, I have an adjustable pushrod to be used for that purpose.
I'd like suggestions for a timing chain.
That's a question I have to ask Ken. He's not available today.
I'll attach the specs. I don't know if that tells you?
First off ... I am no cam expert .
But dont the ramps look really slow for a roller cam ? 218 @ .050 and 293 @ .002
I am running one of Kens cams in my 5.9 and have a similar ramp .
Am I looking at this wrong ?
9.8 reacompression you might be more than ok with the current cam
depending on your gearing and rev range you want
you would have a bunch more dynamic compression which is good unless too much
see if ken will let you test it
where's aj when we need him
