46re acts like its in forward and reverse at same time
Transmission and Drivetrain Tech
  1. 1973dust
    1973dust FABO Gold Member FABO Gold Member
    94
    30
    Jan 12, 2011
    Illinois
    Local Time:
    2:43 AM
    This is not an a-body related question, but it seems like the tech knowledge on this site about anything Mopar is the best you can find on the web. My son has a 2000 Ram 4x4 with a 5.9
    and a 46RE. The truck will not drive forward or reverse and will not even roll with the trans shifted to neutral. The engine is definitely under a load when trying forward or reverse. It will roll with the transfer case shifted into neutral. When shifting the trans into reverse or drive, it feels like a normal shift into gear. I'm hoping that we might get lucky and the problem could just be a stuck shift valve but I've got very little experience with trannys. Hoping one of you gurus can give me an idea what to look at.
  2. CudaFactHackJob
    CudaFactHackJob FABO Gold Member FABO Gold Member
    1,360
    479
    Mar 17, 2016
    Hemet, Ca.
    Local Time:
    2:43 AM
    What's in the pan?
  3. 1973dust
    94
    30
    Jan 12, 2011
    Illinois
    Local Time:
    2:43 AM
    Have not looked yet. We'll drop the pan tonight and expect the worst. I actually did get it to idle forward about 20 feet last night seemingly normally. Then after trying reverse, it would only drive forward with lots of throttle and was not smooth.
  4. Tooljunkie
    Tooljunkie King of cobble/master of the broken bolt FABO Gold Member
    15,788
    15376
    Jul 22, 2017
    Manitoba
    Local Time:
    2:43 AM
    Its done. You should expect to find chunks in the pan. Course of action for me would be a rebuilt if truck is in decent shape, if rough around the edges i would think about finding a used one.
    • Agree Agree x 1
    • Tooljunkie
      15,788
      15376
      Jul 22, 2017
      Manitoba
      Local Time:
      2:43 AM
      Dont forget to pull drain plug on transfer case, it could be piled up. Also, i assume the truck will roll with it (t-case) in neutral?
    • fklskv
      fklskv Well-Known Member
      1,184
      628
      Aug 14, 2011
      Lackawanna, NY
      Local Time:
      3:43 AM
    • 1973dust
      94
      30
      Jan 12, 2011
      Illinois
      Local Time:
      2:43 AM
      Yes, it will roll with transfer case in neutral. T-case was my first thought but it is working properly.
    • 1973dust
      94
      30
      Jan 12, 2011
      Illinois
      Local Time:
      2:43 AM
    • Loggato
      Loggato Well-Known Member
      212
      222
      May 28, 2019
      Central Kansas
      Local Time:
      2:43 AM
      Sounds like when my old 93 GMC pooped it's 4L60E. It had just enough guts to get onto the ramps so I could change it out. Was definitely under a huge load but the truck would barely move.
    • fklskv
      1,184
      628
      Aug 14, 2011
      Lackawanna, NY
      Local Time:
      3:43 AM
      Had issues twice. The other day it stayed in second. Time Before it stayed in first.
    • 1973dust
      94
      30
      Jan 12, 2011
      Illinois
      Local Time:
      2:43 AM
      Okay, thanks for everyone's input. Dropped the pan tonight and no huge chunks but lots of aluminum shavings. Something obviously is coming apart.
    • CudaFactHackJob
      1,360
      479
      Mar 17, 2016
      Hemet, Ca.
      Local Time:
      2:43 AM
      Use a magnet to make sure it's aluminum.
    • 1973dust
      94
      30
      Jan 12, 2011
      Illinois
      Local Time:
      2:43 AM
      First thing I did. Its definitely non-magnetic. As far as the black crud they always have, it didn't actually look bad. Fluid looked decent also.
    • fklskv
      1,184
      628
      Aug 14, 2011
      Lackawanna, NY
      Local Time:
      3:43 AM
      Not my money but if the fluid is good and not burnt up I would try replacing the modulators and solenoids.
      Crap in the pan is not unusual.
      Worst that can happen is you reuse them on a rebuild. IMHO
    • 1973dust
      94
      30
      Jan 12, 2011
      Illinois
      Local Time:
      2:43 AM
      Some of the aluminum pieces are 3/8 to 1/2 inch long and a lot of them are 1/8 ish. Does stuff like that show up in a properly operating trans? If it is dead, we don't intend to rebuild. We'll look for a used trans. Truck not worth putting the amount of money into that a rebuild would cost. I'll try to take pics of debris and post after work today. Thanks again for the input.
    • CudaFactHackJob
      1,360
      479
      Mar 17, 2016
      Hemet, Ca.
      Local Time:
      2:43 AM
      Sounds like planetary pieces. But here's the thing. That trans is a complicated piece of machinery, but the front half is generic old 727 that hundreds of people on here are very very familiar with. If the overdrive is destroyed, I say forget it; it's beyond your capabilities. BUT, I would at least drop out the pump and the two front drums for an inspection before you go with a used unknown. One step at a time. We don't make decisions prematurely that aren't even required yet. Oh, and we like pics...LOTS of pics.
    • 1973dust
      94
      30
      Jan 12, 2011
      Illinois
      Local Time:
      2:43 AM
      Ok, here are some pics of the debris. Ignore what appears to be small rocks. Oil-dry got in the mix somehow. The bottom pic is all magnetic crap. Largest piece is about a 1/4" square. The magnet is about 1 1/4" dia. for size references.
      I also got a better description of what happened from my son. Some of it will be a repeat.
      He noticed a "jerk" pulling into his girlfriends driveway. He put truck in reverse and backed up about 10 feet and then pulled forward. Said it seemed fine.
      Later that night, got in to come home and said when he shifted into reverse it made a loud bang or pop. Tried to back up and truck would jump a little when revved. Said he only tried a couple times. Shifted back into D and tried to pull forward with same result. Shifted to 2nd and was able to pull forward about 20 feet to get out of middle of driveway but took lots of throttle.
      The truck will not roll with transmission in neutral. Acts just like its a manual with the clutch out and in gear. It will roll with the transfer case in neutral. I tried reverse again at home but would not move. I then shifted to D and was able to idle forward to the end of the driveway like normal. I then tried reverse again with same result as before. Back to D and then would only move with heavier throttle than normal.
      Also, the two "levers" in this picture both have about 1/4" free play up and down. Not sure if that tells anything good or bad. I believe the one on the left is the low/reverse band adjuster?
      Hopefully some of my ramblings have made sense.
    • Northern Grit
      Northern Grit Well-Known Member
      156
      199
      Jul 21, 2020
      Michigan
      Local Time:
      3:43 AM
      The 1/4" play is not unusual for a used trans. The description of events really sounds like a broken planetary carrier or in an extream case a blown out rear spragg. But what's in the pan is enough to indicate that that trans is now a core, the only reason to go through it would be only curiosity, the part costs add up so quick that it's not reasonable to try and save it vs installing a used (sometimes with a warranty). Also replace the torque converter.
      • Disagree Disagree x 1
      • 408 swinger
        408 swinger FABO Gold Member FABO Gold Member
        1,860
        1588
        Nov 12, 2010
        Iowa
        Local Time:
        2:43 AM
        Direct drum piston return spring failure. Combined with fried clutch plates.
        • Agree Agree x 1
