I'm having a little trouble with my front servo spring as it doesn't seem to fit on the front servo piston rod guide properly.
I have a 5.0 front servo and this is the spring that came out of it. As you can see by the pictures the spring sits on top of the perches not in the middle of the perches which is how I would assume the spring should sit.
Is this how the spring is supposed to be on the 5.0 front servo or does anyone have the correct part # or spring size for the 5.0 front servo spring?
As always thanks a bunch!
