Hi, i put a 5.2 Mag together for a friend with low budget. Had two engines, one had a rusty bore due to water, the other one had some crank problems - so i made one out of two. Just reused all crank / rod bearings and piston rings, put a 5.9 Cam in it because the stock one was pitted badly. 5.9 cam was all i had at the moment.....heads are untouched, crosswind airgap copy, 625 street demon carb, msd streetfire ignition with stock mopar electronic distributor (modified to around 14° mechanical advance, 20° initial, 34°total without vacuum). Some cheap summit headers and magnaflow mufflers.
This thing is running totally smooth, he got a best 13.3 out of it with slicks (1970 4dr Valiant). 3.55 Gears afaik, stock 904 converter.
We´ll try to dip into the 12s, asked oregon cams about a mild hydraulic roller grind (#1341), if that works with stock parts i´ll do some porting this winter....for what we do have in it, it´s a nice runner and he´s having a lot of fun! There´s a lot of potential in it.
Michael
