63 Dodge Dart, now let me see;)
Maybe this will help. :)
I have a ballast resistor on my 71 Challenger that has a MP Ignition kit in it, but it still has a factory 3 wire alternator. I'm not quite sure if the alternator is the determining factor for a ballast resistor or not?
The MP instructions with the ignition kit says to cut the unused green wire with red tracer off plum up to the plug.
The ignition coil and on Mopars the ignition box are determining factors for a ballast resistor. In short, if you are using the Mopar style electronic ignition with the factory style ignition box, you must use a ballast resistor. @halifaxhops can give you the hookup if you need one.
OMG, the cool front came through and it's glorious here! I'm not sure what the ballast resistor came out, suppose it will work. Got the radiator to fit my stand, ordered a carburetor, spark plug wires, hm, Does this system use a starter solenoid? like on a fender? All the others were easy for my Bronco with the solenoid on the inner fender.
oh, I have the old valve cover, I see some mutilate a valve cover for valve adjustments? Any pics or is it worth it? Will it make a mess without something to catch the oil?
I worked at a shop that was Mopar only in the 70's for Larry Callahan (Big Daddy Mopar LOL). We had 2 sets of 273 valve covers cut open to do adjustments with. It was handy but we were doing a lot of cars so it was worth it. If you had an old one that would never be needed...sure why not.
It would have wound up in the trash, so I hope this helps keep the engine a little cleaner when adjusting valves. Even the cut piece makes a good cover;)
You may find the cut cover unneccessary. Slants oil the top end dribbling oil out of the rocker arms. I've never had one splash or drip, even when setting hot with the engine running. YMMV of course, but it's a whole lot cleaner operation than my old 350 Chevy.
Well, have to have fuel :lol:~ the cover on the hose is temporary, just makes it look neat. I'll put some small brackets in the mix. I may have to change it all up when the alternator is here, but, meh, good experience playing the fuel line. Fuel filter will go before the pump in my case. I think I'll make a little "heat shield" at the bend by the exhaust manifold.
dne'
