64-66 abody radiator brackets for shroud
Heating / Cooling / AC
  1. Syleng1
    Syleng1 Karma is real and Life is short... FABO Gold Member
    1,865
    1440
    Jul 5, 2005
    North Franklin, CT
    Local Time:
    4:15 AM
    I’m looking for the 4 molded “z” brackets that hold the coolant shroud to the radiator on the 64-66 radiators.
    thank you! Joe- Thanks 65 Dartman for the photo!
    • Like Like x 1
    • 65 Dartman
      65 Dartman FABO Gold Member FABO Gold Member
      11,638
      3210
      Sep 24, 2006
      Strasburg, VA
      Local Time:
      4:15 AM
      If my memory serves me I probably have a set or two that I had Leanna do for me. i’ll get back to you later today.
    • Ccas
      Ccas FABO Vendor FABO Vendor
      224
      158
      Dec 7, 2016
      Hatfield, PA
      Local Time:
      4:15 AM
      is that shroud OEM? If yes, we'd be interested in making both the shroud and the brackets.
      If yes, can you take a couple pics of just the shroud? It looks 2 piece. You can post them or send them to chrisc@coldcaseradiators.com thanks!
    • Syleng1
      1,865
      1440
      Jul 5, 2005
      North Franklin, CT
      Local Time:
      4:15 AM
      I have a factory shroud. But need the Molded z brackets. I can send photos in a Email in a few.
    • Syleng1
      1,865
      1440
      Jul 5, 2005
      North Franklin, CT
      Local Time:
      4:15 AM
      Thanks mike!
      #toolmanmike
      • Thanks! Thanks! x 1
      • Syleng1
        1,865
        1440
        Jul 5, 2005
        North Franklin, CT
        Local Time:
        4:15 AM
        Just sent Chris.
        • Like Like x 1
        • Ccas
          224
          158
          Dec 7, 2016
          Hatfield, PA
          Local Time:
          4:15 AM
          I see now that those brackets have already been reproduced.
          NEW Mopar 1962-65 B-Body Fan Shroud Brackets | eBay
          However, I dont' see a reproduction of the shroud. One thing I noticed is that the application is 62-65 and 1966 appears to be different? Can someone shed some light on the A-body shroud year ranges and differences?
          Anybody have a 62-65 fan shroud they want to let us borrow? :)
        • 65 Dartman
          11,638
          3210
          Sep 24, 2006
          Strasburg, VA
          Local Time:
          4:15 AM
          There were 2 different shrouds for 65/66 early A’s - IDK if a shroud was even available in 63/64 unless it might have been fir a HD cooling option. If so it would have been the 19 inch version as the 22 inch radiator wasn’t available until 65. Generally speaking in 65/66, slants got a 19 inch radiator with the corresponding size shroud whereas V8’s got the 22 in radiator with the corresponding size shroud. FWIW I’ve never seen a factory 22 inch slant radiator in a 65/66. Additionally, to secure the factory shroud with the factory brackets, the user needs to have the correct radiator side panels to install the brackets
          I have a 65/66 slant shroud if desired; I also have a 65/66 V8 shroud I might let you borrow depending on how hong you'd have it.
          • cudamark
            cudamark FABO Gold Member FABO Gold Member
            7,204
            462
            Mar 14, 2009
            San Diego
            Local Time:
            1:15 AM
            As far as I know, all the '65-6 V8 shrouds are the same. '64 and earlier A-bodies didn't have a 22" radiator, so, no application there except maybe they fit the B-bodies?. The 19" ones for the 63-4 slant 6 should all be the same too. In '65-6 a slant 6 with A/C would have gotten the 22" radiator and a shroud made for just the 6cyl. They're metal 2 piece shrouds. Are you going to make them as exact reproductions?
          • 66340SEDAN
            66340SEDAN FABO Member #3649 FABO Gold Member
            26,626
            27973
            Nov 20, 2006
            Minnesota
            Local Time:
            3:15 AM
            These brackets are unique and very hard to find....think the repop b-body ones are a little different....I have some I can get a picture of later on if needed
            • Agree Agree x 1
            • cudamark
              7,204
              462
              Mar 14, 2009
              San Diego
              Local Time:
              1:15 AM
              They claim those repops are the same as the A-body. Anyone have a genuine B-body one to take some measurements?
            • Ccas
              224
              158
              Dec 7, 2016
              Hatfield, PA
              Local Time:
              4:15 AM
              Yes, that was my thought. We've made plenty of restoration parts in our other company and this 2 piece metal shroud looks doable.
            • Ccas
              224
              158
              Dec 7, 2016
              Hatfield, PA
              Local Time:
              4:15 AM
              I saw a B-body version on ebay and at first glance it looked the same.
            • Ccas
              224
              158
              Dec 7, 2016
              Hatfield, PA
              Local Time:
              4:15 AM
              The 6 cylinder one looked much harder to do. So we'd like to try the v8 one. Once I have it in hand, I could tell you how long we'd need it. It could be 3-10 weeks but more likely the lesser time frame.
            • cudamark
              7,204
              462
              Mar 14, 2009
              San Diego
              Local Time:
              1:15 AM
              Yes, same design, but, do they actually measure the same?
            • 65 Dartman
              11,638
              3210
              Sep 24, 2006
              Strasburg, VA
              Local Time:
              4:15 AM
              I am looking through my 65 parts manual and according to it, the part number for the 6 cylinder Dart/Valiant and the 8 cylinder Coronet/Belvedere shroud brackets are the same - 2099 555. The part number for the V8 DartValiant is 2524 494. Not sure what the difference is but with different part numbers, there must be some kind of difference. Shroud part numbers for 6 and 8 are different between 6’s and 8‘s both models
              i looked at radiators as well - the manual lists them for Standard, High Altitude and AC for 6’s and 8’s. High Altitude and AC use the same part numbers for the 6 and different ones for the 8 for standard, high altitude and AC. They didn’t list widths. Hope this helps someone
            • 65 Dartman
              11,638
              3210
              Sep 24, 2006
              Strasburg, VA
              Local Time:
              4:15 AM
              i am hoping to finish my restoration/panel wagon conversion before your 10 week time frame. Based on that, I’d prefer to not loan it out; i’d be happy to let you borrow my slant shroud though.
              • Like Like x 1
              • Dartsun
                Dartsun Member
                1,462
                1039
                Feb 12, 2012
                Springfield Oregon
                Local Time:
                1:15 AM
                66 V8 992F1904-2915-4A34-92B6-83A7A54C9417.jpeg E39C260C-C5ED-46B9-9E77-024A55B04FC9.jpeg
              • cudamark
                7,204
                462
                Mar 14, 2009
                San Diego
                Local Time:
                1:15 AM
              • Dartsun
                Dartsun Member
                1,462
                1039
                Feb 12, 2012
                Springfield Oregon
                Local Time:
                1:15 AM
                The bolts are generic ebay “b body” ones for the brackets. Brackets and shroud are original.
              • Syleng1
                1,865
                1440
                Jul 5, 2005
                North Franklin, CT
                Local Time:
                4:15 AM
                I just ordered the EBay set of b body / 66 abody ones so I will know in about a week if they are in fact plausible. The one in the photos I sent Chris at cold case today via email (66’ V8 rad shield) is verified original and even the bolts holding it together should be factory. I’m curious if the repop brackets are correct. 8E06C75B-A073-4171-B003-864C11A0ECBB.jpeg 8F192E6B-7530-41DC-BA26-2116104DB6DB.jpeg C9A8869C-00DD-4FDB-89E8-932135BAC2B5.jpeg BC6BE4F4-A7F5-4C63-A668-3F96D2609761.jpeg
                • Like Like x 1
                • Syleng1
                  1,865
                  1440
                  Jul 5, 2005
                  North Franklin, CT
                  Local Time:
                  4:15 AM
                  Quick question 65 Dartman- in your parts book do you list a radiator ending in 28 and 30 for the 66’ abody? I sent my 66 273 Abody radiator for auto ending in 28 out today for recore and I kept my manual trans 66’ radiator ending in 30. Both have an “AC” stamped in the top tank left side - right side has the part number. I’m curious if the “AC” is for air conditioning or just a build code.
                • Big_John
                  Big_John In my defense, I was left unsupervised.
                  370
                  383
                  Nov 16, 2014
                  Syracuse, NY
                  Local Time:
                  4:15 AM
                  I would be interested in one if it is a good reproduction and looks/fits/functions like the original and mates to my "correct number" radiator.
                  • Like Like x 1
                  • 65 Dartman
                    11,638
                    3210
                    Sep 24, 2006
                    Strasburg, VA
                    Local Time:
                    4:15 AM
                    I will check however my parts book is for 65 so the numbers might be the same or not. I would venture to guess the “AC” would indicate a radiator for air conditioning.
                    • Syleng1
                      1,865
                      1440
                      Jul 5, 2005
                      North Franklin, CT
                      Local Time:
                      4:15 AM
                      #65 Dartman,
                      I checked on MyMopar.com and down loaded the parts book for 66'
                      I cannot verify that number at all. It falls within the range of part numbers but not listed.
                      #2582930 Manual shift 273 with a/c
                      #2582928 Automatic shift 273 with a/c
                      I wonder if anyone lese knows what those two part numbers I have are listed for (a/c or Not a/c- that is the question- Shakespeare)
                      EDIT- UPDATE: I ran both numbers on the radiator part number look up on MyMopar.com. It says the number 2582928 is a /6 22" radiator for early A.
                      I wonder if that is wrong or at one time the top tank was replaced with another.
                      The manual trans comes up proper 2582930 273 std cooling.
