I am going to wire anything that needs to go through a fuse directly to the hot or run/ACC sides. Hot side includes the parking lights, the brake light switch, and the lighter all on separate fuses. Some other hot wires tie into one or more of these hot wires are the hot side of the courtesy lights, time delay relay, chime, and main headlight swich hot, etc. Other stuff that will have separate hot fuses is the relays, power seat (circuit breaker) and power lumbar support. On the run/ACC side I will have the heater blower switch, power windows (circuit breaker), heated seat relays, and certain circuits for the Dakota Digital components. The turn signal switch has it’s own separate fuse from the ignition switch as does the Hazard warming switch. These fuses are located in the separate fuse panel. There’s a couple of other separate circuits as well.
Don. Very Nice. Keeping all of the wiring, where they go, wire size for amperage capabilities, and etc would be an effort for certain....Anyway for me. Great work. Sgrip65
