66Dvert
Working on my custom car parts again!
I'm in the middle of the inter fitment. just waiting on the carpet to come in so I can get the console made and fitted to the seats. I'm using the stock shifter and plate but going with a foam/fiberglass style console so that I can get things situated the way I want em too! I'm moving the power top switch, power window switches,trunk release and 2 A/C vents (1 in the front and 1 in the rear of the console)down on the console. that should give me initiative to get cracking on setting up an Digital instrument cluster and bezels cast out of acrylic to smooth out the dash cluster and hide the fact that it is going to be digital until I turn the key on. I've seen a couple of clusters that might fit without being to gaudy and can be hidden behind a dark lexan lense, but will still show the gauges. here's some pic's of the seats in the correct location now and partial covering of the back seat for the convertible well liner setup
I still have to bend the side pieces up and finish the mounting brackets on the sides. but it's solid and the seat belts are mounted AND working.
testing the electrics for the power windows and the power seat, fixed the bad motor for up and down.
back seats a little tight using stock side panels I'll have to trim 1/2 inch off the sides to relax the foam so it fit's better and looks better too!
as you can see the seats are not that much higher than the original ones and should work nicely. plus it's got a nice top finish trim that I'll have to clean up so it looks even better.
and yeah I'm going to the lower ride height. I'll have the springs reworked to get me to this height after the engine is in.
